Another alternator problem..
  • coppertales
  • coppertales's Avatar Topic Author
05 Sep 2008 07:20
#235621
I also have an alternator with low output. I replaced the rec/reg thinking that was the problem. All electrical contacts were cleaned and the battery fully charged. I know it is a good battery because I took it out of my other bike which is my daily rider seeing the red bike is down. Pulling the battery box, with all the electrical connectors, is an adventure if you have not done it before. It had been a long time for me. With the installation complete, I fired the bike up and after warming up, only 12.4 vdc was measured across the battery terminals, no matter what the rpm. I ohm checked the stator, again, and the three windings are not shorted to each other or the case. I then did a voltage output check and all three windings are only putting out 12.2 vac, no matter what the rpm. The manual says the rotor may have lost it magnetism, or the stator is bad. Luckily, I have another rotor. I sure don't want to pull on off one of my good bikes just for troubleshooting. I will inspect the stator when I have the cover off too......chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • MFolks
  • MFolks's Avatar
Re: Another alternator problem..
05 Sep 2008 19:31
#235734
With the stator disconnected from the regulator/rectifier and the engine running at 3-4K you might have 70 Volts Alternating Current(A.C.) Have you done this check with the alternator out of the circuit? This will determine if the alternator is putting out what it should.
  • coppertales
08 Sep 2008 07:37
#236126
Yeah, I did the ac voltage check and no joy, even with the replaced rotor. Looks like the stator is bad. Bummer. I guess I will pull the stator off my other bike, which now had an ignition failure. I really did not want to do that because it took me forever to get the oil leak on that bike stopped. Oh well.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
