1978 KZ650 DSR, no spark
- mineral723
04 Sep 2008 23:42
I'm new and I recently bought a '78 kz650 dsr. I paid $20 for it and I am in the process of restoring it. Bike has only 8,000 original miles on it. Sat outside, then garaged for about 10 years, never ridden.
Only problem is that it gets no spark.
First off, I checked the spark at the plug boot. No spark. Checked power going from the coils. No power. Checked power going to the coils. No power.
Checked points. Points were dirty with a small layer of green corrosion on the contacts. I cleaned the points and reinstalled them.
Then I checked the power going to the contact points. No power coming into the contact points.
Where do the green and black wires come from and what could be causing no power to get to the points?
Other than that, the restoration process has been fun. If I can get spark, I will continue restoring the bike and should be riding by springtime.
Thanks for the help.
- wiredgeorge
Re: 1978 KZ650 DSR, no spark
05 Sep 2008 06:02
The black and green wires are the wires that carry electricity from the points to the coils. The black wire comes off the left set of points as you sit looking at the points with the points cover removed. The green comes off the right hand points assembly. The black wire is the 1&4 wire and the green the 2&3. Power to the coils comes off a yellow/red wire that comes out of the right hand switch gear. Turn the ignition key on and see if there is 12VDC present on the yellow/red. On some KZs, this wire may be red or pink. Go to my website and read the tech article called Coil Repowering under wg's Tech Stuff Index and it will give you a good idea of flow. If you are getting no spark, either the condensors associated with the points are shot or you have no power at the coils.
What I do when I redo an old bike is to remove the points plate (and points/condensors), remove the wiring, remove the coils and remove the spark plug wires. I order a Dyna S electronic ignition, Dyna green 3 Ohm coils and new Dyna plug wires. I also perform the coil repowering modification from my website. I install this stuff and never mess with it again. Dyna products are very inexpensive when you buy them from www.z1enterprises.com - one of the fine bike parts sellers who supports this site through advertising. Call them and tell them I sent you. If you dump the points and go with new coils/wires, your bike will be maintenance free for years and you will not only save time (no tune up needed) but money as the points/condensers are expensive.
