1980 z1-g classic miss & wire question
  • gnfreak
  • gnfreak's Avatar Topic Author
04 Sep 2008 06:45
#235433
before i start blaming the fuel injection system, i want to cover the basics. background- seemed to run pretty good over the weekend (kinda lousy gas mileage though), drove to work tuesday nite, when i started it Wed. morning to go home had a noticable miss like running on 3 cylinders. got it home (3 miles) and started digging in. number 2 spark plug resistor cap(NGK) fell of the wire. cut back alittle of the wire and reinstalled. checked plugs and #2 is black compared to the others. cleaned it up and test drove. now getting a lot of popping below 2500 rpms and at idle. i want to change plugs and wires but am unsure if i need to keep the NGK resistor caps. Z1Enterprises sells the red wires i want but they end in just a regular boot. and do i need suppression wires because of the FI computer? after some rest today i plan on switching #2 and #3 wires from the coils and see if the black plug follows the wire. also want to do a compressin check while the plugs are out. searching here on KZR looks like a regular carb cleaning would be in order but i have the fuel injection to mess with. sorry for the length of this post
Normal, IL
1980 KZ1000-G1 Classic - Sold
  • MFolks
  • MFolks's Avatar
Re: 1980 z1-g classic miss & wire question
04 Sep 2008 14:37
#235505
It might be time to replace the original coils as they break down with heat and age. www.z1enterprises.com sells the Dyna coils cheaper than the Dyna website does at www.dynaonline.com
Another suggestion would be to do the "Wired George" relay modification bypassing the current dropping wire harness you have probably got. His website is www.wgcarbs.com and instructions and parts are listed.
There are some recent posts about how much better the bikes run after doing this modification.
  • coppertales
  • coppertales's Avatar
05 Sep 2008 10:28
#235646
I have been running two sets of the Z1 red wires with the regular caps and they perform just fine. I don't know about any interference though....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • gnfreak
05 Sep 2008 16:13
#235690
talked to someone at z1 today and he said to use the suppression wires w/o resistor caps because of the computer. ordered up a set today and bought a new set of plugs. will mess with it when wires come in. thanks for the replys.
Normal, IL
