Is the headlight supposed to dim when the brake light is on?
- ghunt81
28 Aug 2008 07:41
Just wondering, I happened to notice that when I hit the brakes and the light comes on, the headlight dims...is that normal?
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
- patmann
Re: Is the headlight supposed to dim when the brake light is on?
28 Aug 2008 08:19
Not on my bike..
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- BSKZ650
28 Aug 2008 09:21
no that is not supposed to happen, check the grounds on the bike, also make sure it is charging correctly
77 ltd1000, current rider
76 kz900, just waiting
- bountyhunter
28 Aug 2008 15:14 - 28 Aug 2008 15:16
duplicate
Last edit: 28 Aug 2008 15:16 by bountyhunter.
- bountyhunter
28 Aug 2008 15:15
ghunt81 wrote:
If the engine is idling (and you are running off the battery) it could very well dim the headlight if you step on the brake, but the effect should be small.
FYI, you can actually see the headlights dim and brighten a little as you let the engine drop to idle then rev it a bit. The reason is:
At idle, when you are running off the battery, the system voltage is about 12.5V. When you rev it, the bike's system voltage rises to 14V and that makes all the lights a little brighter.
