I am not retarded. Should I be?
- BSKZ650
Re: I am not retarded. Should I be?
25 Aug 2008 06:06
Dont use the octane booster, The crap does not mix even with the fuel, learned this the hard way with a hole in the piston.
If you havent tried super unleaded then adj on the timing can help.
77 ltd1000, current rider
76 kz900, just waiting
- mtkawboy
25 Aug 2008 08:49
You could buy a can of race gas at an automotive performance place that sells to drag racers & mix it but thats not too handy on long rides. Slot the holes on the timing plate {?} to where it will turn and retard it a bit and see how it goes
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
25 Aug 2008 10:45
Any advice on how many degrees to retard it? How far is too far?
West Linn, OR
- BSKZ650
25 Aug 2008 11:12
I would work in 2 degree increments, I dont think you should move more than that.
on another thought, what about maybe trying one step colder plugs, just a thought
- Skyman
25 Aug 2008 11:49
BSKZ650 wrote:
Yeah, that was suggested earlier in this thread. I may try that first. Are there any potentially undesirable side effects to going with colder plugs?
West Linn, OR
- bountyhunter
25 Aug 2008 13:10
Skyman wrote:
They will foul frequently in city riding where you are not revving up a lot.
BSKZ650 wrote:on another thought, what about maybe trying one step colder plugs, just a thought
25 Aug 2008 13:27 - 25 Aug 2008 13:35
Skyman wrote:
[quote... any potentially undesirable side effects to going with colder plugs?[/quote]
FSM cautions that a colder plug may not run hot enough to keep the carbon burned off; then goes on to warn that the carbon build-up can heat up red-hot and cause preignition and knocking, which may eventually burn a hole in the top of the piston.
Accordingly, imo it would be a good idea to read the colder plugs often to assure running hot enough to stay tan color, and if not (appearing carboned or sooty), return to the standard size plug giving the tan color reading.
Good Luck!
P.S. -- If testing the colder range spark plugs, would do that first before retarding the timing, so the remedial efforts are not mixed together without knowing which if either change has the most effect.
Good Luck!
Last edit: 25 Aug 2008 13:35 by Patton.
- Skyman
25 Aug 2008 15:16
Patton wrote:
Roger that. Thanks!
Roger that. Thanks!
West Linn, OR
