I am not retarded. Should I be?
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
23 Aug 2008 14:46
I am talking about my ignition, of course! :laugh:
On my KZ1000 M2, I have 1135 10.25 Wiseco pistons and '84 GPz cams.
When I twist the throttle and put a load on it, the engine seems to always ping quite a bit until the load is reduced.
I know that some pinging is normal, but how much is too much?
Would it be a good idea to retard my ignition some? If so, how much?
From what I understand, this is done by rotating the igintion pickup plate, correct? Do I rotate the plate clockwise or counter-clockwise to retard the ignition? I'm guessing clockwise, right?
My pickup plate does not have slots to adjust the plate, so I will need to cut them. Any advise would be helpful and appreciated.
Thanks.
Thanks.
West Linn, OR
- RonKZ650
Re: I am not retarded. Should I be?
23 Aug 2008 15:59
Yes, clockwise retards the ignition. I had Wiseco 10.25-1 pistons in a GPZ1100 and it was too high for pump gas and this was 1983 when octane was higher than now. Good luck.
- Bluemeanie
23 Aug 2008 16:07
Retarding your timing will soften up your bottom end some but will pick up your top end also. Let us know...
- KZQ
- Administrator
23 Aug 2008 16:12
Hi Steve,
Not suggesting this is a long term solution but have you tried adding some octane booster?
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Skyman
23 Aug 2008 16:39
KZCSI wrote:
No, I haven't tried that. I guess I could give it a try. But as you said, this is not a good long-term solution. I don't want to have to use it all the time.
Hi Steve,
KZCSI
West Linn, OR
- KZQ
- Administrator
23 Aug 2008 17:53
For sure not! But it would define you're issue.
Or at least let you taste what's available!:woohoo:
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
23 Aug 2008 18:54
Imo, zero pinging is best.
Probably already done or considered,
but besides timing, am thinking:
Running high octane (pump) gas?
Compression psi too high (beyond factory specs)?
Carbon build-up in combustion chamber?
Correct spark plugs and gaps? Plug reading?
Perhaps try one step colder range plug?
Feasibility of using two base gaskets
to slightly lower compression?
Good Luck!
Good Luck!
- quader98
23 Aug 2008 20:10
sorry,not that i do it but why is octain boost not good to use all the time
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
82 GPZ 750 R1
- Bluemeanie
23 Aug 2008 20:37
It would not hurt to use it long term, problem is that how much could you carry with you on a long Sunday afternoon cruise? You would need to play chemist every time you put gas in. It's a real pain in the arse! I had a '69 AMC Javelin with a built 390 that I had to use octane booster and to play chemist while putting in $5,$10, or $20 of gas (back in the 80's when gas was $1.00 a gallon) and figuring out the gas to booster ratio was a pain. Not to mention having 5-6 cans in the trunk at $5 a can! Not worth it long term.
- Skyman
23 Aug 2008 20:56
Bluemeanie wrote:
What he said.
What he said.
West Linn, OR
- quader98
23 Aug 2008 20:56
aaaaahhhhh
82 GPZ 750 R1
82 GPZ 750 R1
- Skyman
23 Aug 2008 21:01
Patton wrote:
Thanks for all the good suggestions.
FYI, compression is 155-165-155-165.
Plugs are B8ES. All read tan now (I was previously getting soot in #1 only, but fiddling with the carbs, I think I finally got that problem solved). I guess I could try B9s.
Two base gaskets? [sigh] I guess I COULD try that. Just not too excited about tearing down the top end again. Maybe over the winter.
Thanks again.
Good Luck!
Thanks again.
West Linn, OR
