Turn signal flashing question
- harm
- Tom
23 Aug 2008 11:49
I put some LED turn signals on the back of my 550 but they do not flash. I didn't have any blinkers before. My question is do i need a complete circuit so they will flash? At this time i do not have front signals. My indicator lights are working. I have two flashers that i tried but i am not sure if either are good. I thought i would ask before buying a new flasher.
Thanks!
Tom
Thanks!
Tom
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- Royal1MC
- Is it just me, or is it just great to be on a KZ
Re: Turn signal flashing question
23 Aug 2008 12:02
Yes, hooking up one side of the turn signals(either both left side or both right side) will complete the curcuit.
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Los Angeles, CA
- Vter Bob
23 Aug 2008 12:55
Sometimes LED bulbs will not flash with the old style flasher units that were triggered by the load on the circuit. You might need to replace that unit with a new electronic flasher unit available at any auto parts place. Usually $5-$6.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
- bountyhunter
23 Aug 2008 13:45 - 23 Aug 2008 13:46
harm wrote:
Superbrightleds.com used to sell the flashers.
You need a solid-state flasher to use with LED turn signals. They don't draw enough current to make a standard flasher unit flash.I put some LED turn signals on the back of my 550 but they do not flash. I didn't have any blinkers before. My question is do i need a complete circuit so they will flash? At this time i do not have front signals. My indicator lights are working. I have two flashers that i tried but i am not sure if either are good. I thought i would ask before buying a new flasher.
Thanks!
Tom
Last edit: 23 Aug 2008 13:46 by bountyhunter.
- harm
- Tom
23 Aug 2008 17:55
Okay, i will try a solid-state flasher. So do i also need front signals to complete the circuit as Royal1MC mentioned?
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- bountyhunter
24 Aug 2008 14:20 - 24 Aug 2008 14:20
harm wrote:
NO. The front and rear turn signals are wired in PARALLEL, so a solid state flasher will flash a single turn signal just fine, or both if they are both connected. The reason stock flashers require both turn signals be connected to work right is the metallic flasher piece requires the current of BOTH front and rear bulbs to make the metal strip hot enough to curve which makes them flash.
Last edit: 24 Aug 2008 14:20 by bountyhunter.
- Royal1MC
24 Aug 2008 21:14
Thanks bountyhunter for clearing that up. I didn't fully get the part about the LED's, cause I have never seen them.
Los Angeles, CA
Los Angeles, CA
