ignition swap
  • Scotty355
  • Scotty355's Avatar Topic Author
ignition swap
12 Feb 2006 08:31
#23326
I am looking to upgrade my points on my 79 650 to electronic, anyone know what bikes I can swap from before I go to the junkyard? I searched thru the archives for about an hour (whew....) maybe I missed it
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: ignition swap
12 Feb 2006 11:05
#23347
KZ/GPZ550, late model 650s, and 750/4s should be an easy swap. You will also need the advancer with cam and an Igniter.
I have put a KZ1000 electronic Ign. in mine, but have yet to fire her up. Just waiting a few more weeks for some warmer temps.
Here's a link to my swap in progress: KZ1000 Ign to KZ650
Post edited by: rstnick, at: 2006/02/12 14:08
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Scotty355
Re: ignition swap
12 Feb 2006 16:10
#23411
thx nick, so basically any 550, 650 or 750 4 cyl electronic ign should fit correct?
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: ignition swap
12 Feb 2006 17:45
#23427
Correct. And hopefully, 1000s too.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • BSKZ650
  • BSKZ650's Avatar
Re: ignition swap
13 Feb 2006 14:15
#23560
why not save the time and hassle of a udes unit that may not work, the dyna is around 120.00 new, and you know it will work, put one on my 650 last year, easy , fast, cheap
77 ltd1000, current rider
76 kz900, just waiting
  • BSKZ650
  • BSKZ650's Avatar
Re: ignition swap
13 Feb 2006 14:16
#23562
fingers too fast should be USED
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: ignition swap
13 Feb 2006 19:25
#23684
My KZ1000 Ign. cost $30 including an Igniter, so it is worth a try. Easier to sneak by the wife as well.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • loudhvx
  • loudhvx's Avatar
Re: ignition swap
13 Feb 2006 20:02
#23705
The stock elec-ignition has a few advantages over the Dyna as well.
1) The stock elec-ignition works with 2.5 ohm coils. Going to a Dyna would require new 3-ohm (or higher) coils on a bike that came stock with elec-ignition.
2) The stock elec-ignition uses less electrical power than the Dyna. It also uses a variable dwell angle which is a little easier on the coils.
3) The Dyna has both coils on most of the time even when the engine is not turning (but the key is on). This is an issue if you want to run without a battery.
4) The dyna S puts all of the electronics right on the engine. Heat and vibration can take its toll on the electronics.
5) If the stock elec-ignition module burns out, you can make a replacement for about $30.
6) Modifying and making stuff is more satisfying than buying stuff. (This is the real reason, probably.)
Post edited by: loudhvx, at: 2006/02/13 23:14
  • Scotty355
Re: ignition swap
14 Feb 2006 19:07
#23927
Hey loudhvx I do like to do things the "hard way", I have converted old chryslers from points to electronic using all junkyard parts before and have found that when things do go wrong ,and they will, I have the knowledge to figure out the problem but I never built a module before. How would I do that?
  • loudhvx
  • loudhvx's Avatar
Re: ignition swap
14 Feb 2006 23:25
#23987
Here's a couple links:
This one uses GM HEI modules and is very simple.
www.geocities.com/loudgpz/GPZgmHEImod.html
This one you make from scratch.
www.geocities.com/loudgpz/GPZignitionMod.html
I converted a Dodge to electronic ignition. The old "orange" Chrysler module and similar ones seem pretty indestructable, but they are awfully big, otherwise I probably would have used them on the bike.
  • Scotty355
Re: ignition swap
15 Feb 2006 16:06
#24109
Thanks for the info, I'm think I am going to try the HEI mod, thanks again.
