'77 kz650 starting issue...
- Nate77
19 Aug 2008 14:43 - 19 Aug 2008 15:00
I'm having issues with my starter button...when I push it, NOTHING happens...totally silent. I tried bridging the terminals with a screwdriver and it turned over. The light switch works and the rest of my electrical is fine. The bike will kickstart in about 10 kicks but the button is doing nothing. I believe the neutral safety switch is fine. Any suggestions?
1977 KZ650 B1
Last edit: 19 Aug 2008 15:00 by Nate77.
- bill_wilcox100
Re: '77 kz650 starting issue...
19 Aug 2008 18:34 - 19 Aug 2008 18:50
Try wiring your horn directly across the battery, possibly with temporary wires... inline fuse would be wise.
If it does not honk you have a faulty horn. Replace it.
If it honks you have a switch, wiring and or connector fault. Start troubleshooting.
If you have the original Operator's Manual you will find the wiring diagram on the last page in glorious black and white. Use it for troubleshooting.
Best of success.
PS
Remember to add your year, model and location to your signature as it will get you the best responses and is considered real friendly.
Re-PS
What was I smoking... this is the wrong post. :blush:
Had to happen some day :laugh: :laugh: :laugh: :laugh: :laugh:
It's your wiring or start button or clutch interlock switch.
Bill
Best of success.
PS
Re-PS
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 19 Aug 2008 18:50 by bill_wilcox100.
- Nate77
19 Aug 2008 19:17
If the problem was the interlock switch, would I be able to bypass it somehow? or start it with the clutch lever pulled in? I'm not too familiar with it. thanks.
1977 KZ650 B1
- Mark Wing
19 Aug 2008 22:33
Yes you can bypass the switch, mine hasn't been hooked up since 77. Follow the wires back to the plug and hook the wires to each other, switch bypassed.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Limey
- 3 Years in the U.K. - Brought the KZ with me!
20 Aug 2008 07:03
Nate77 wrote:
If it has the clutch interlock switch, then you MUST pull the clutch in to start the bike!
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
1978 KZ650
2000 ZG1000
- Nate77
20 Aug 2008 09:26 - 20 Aug 2008 09:28
Well, I guess it's not the interlock switch. I tried bypassing it and still nothing...tried clutch lever in/out and every possible combination that has to do with the interlock switch.
I guess I'll attack the button itself.
Thanks for all the input by the way!
1977 KZ650 B1
Last edit: 20 Aug 2008 09:28 by Nate77.
- BSKZ650
20 Aug 2008 13:00
if yours still has the wires running thru the bars, get them out, you will be surprised to see all the bad spots from them rubbing.
Your problem does sound like a switch issue, but donr forget to check all the connections in thewiring harness also
77 ltd1000, current rider
76 kz900, just waiting
