Sticking brake light
  • ghunt81
  • ghunt81's Avatar Topic Author
18 Aug 2008 21:40
#232823
I've been having a problem with my brake light sticking on, and I already found the culprit- the actuator is hanging up on the rear brake pedal, making the light stay on.
If it sticks, I can pull the wire a bit by hand and it will pop back in, but it keeps wanting to do it. I tried spraying some white lithium grease on it the other day but it doesn't seem to have helped very much.
What else do I need to do, or did I use the wrong lube?
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
  • HerrDeacon
  • HerrDeacon's Avatar
Re: Sticking brake light
19 Aug 2008 02:56
#232845
The same thing happened to mine. I tried lubing it and that didn't work. So I took it apart and replaced the spring but couldn't get it to function correctly. So I ordered a new one from Z1. It only cost around $7-8.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
19 Aug 2008 07:49
#232869
The switch is probably too corroded internally,so do as suggested,and just order a new one from Jeff at Z1 Enterprises.B)
1977 KZ1000 A-1
  • RonKZ650
  • RonKZ650's Avatar
19 Aug 2008 08:16
#232878
I'll triple the suggestion. You can lube all day and it may work, but won't last. Just replace it.
19 Aug 2008 09:03
#232889
Am thinking the white lithium grease is a little too heavy. Might try squirting some WD40 into both ends of the switch while working the switch back and forth. The WD40 will help clean out the grease and other crud, and maybe help prevent the switch from sticking. :)
  • coppertales
  • coppertales's Avatar
19 Aug 2008 11:11
#232909
Use contact cleaner to spray into the switch. WD40 leaves too much residue and will gum up....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • ghunt81
21 Aug 2008 20:43
#233391
Can I even get a new switch for this bike?
Z1enterprises doesn't list one for this model. Does the one that fits the KZ1000/650/550 fit this bike? Sure looks the same.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
21 Aug 2008 20:55
#233396
It probably IS the same,or you can make it work...got a pic of yours?
1977 KZ1000 A-1
  • ghunt81
22 Aug 2008 06:35
#233429
It looks pretty much just like this one:
www.z1enterprises.com/detail.aspx?ID=2693
except that mine has a right angle cap where the wires attach to it.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
22 Aug 2008 06:55
#233437
Pretty sure you can modify it to work,Garrett.
Chances are,it'll even work as is.
They are adjustable,and you can even use a different length spring to get it set.
I say go for it...spend some money on your ride.B)
1977 KZ1000 A-1
  • RonKZ650
  • RonKZ650's Avatar
22 Aug 2008 10:09
#233463
Bikebandit lists the right one for $15. If it's still available I'd go that routt.
