Found battery drain problem...
- coppertales
18 Aug 2008 07:37
The battery on my 1982 KZ1100A2 was not charging, so I replaced the battery. Everything was ok until I hit a bump and the turn signal, that was on at the time, dimmed. The battery was discharged by the time I got home.
I checked things over, ohm checked the alternator and rectifier, and cleaned the connectors. The alternator and rectifier checked good. When I pulled the 9 pin connector apart, it crumbled in my hand. When the harness was installed, they ran the connector over the frame instead of under it, like on my other two bikes, and it appearantly got squeezed between the tank and frame and over the years, the stress was too much and in now is in little pieces.
Does anyone still make these connectors? I need the male pin half....thanks...chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- JMKZHI
Last edit: 04 Dec 2008 07:26 by JMKZHI.
- Sandy
- Fly High,Tony
Last edit: 18 Aug 2008 08:37 by Sandy.
- coppertales
Re: Found battery drain problem...
18 Aug 2008 11:56
Thanks guys. It seems like every time I look on the Z1 web site, there is something new there.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- MFolks
18 Aug 2008 13:11
Some more websites for connectors:
www.vintageconnections.com , www.vehicle-wiring-products.com
www.electricalconnection.com , www.wiringproducts.com ,
www.painlessperformance.com
