KZ750 starter clutch
  • Sims426
  • Sims426's Avatar Topic Author
17 Aug 2008 15:24
#232535
I just picked up an 82 KZ750 twin. It will turn over for a few seconds and then make a grinding noise. I'm told this is the starter clutch. Is there a how-to on removaland rebuild for this? I've tried searching and I can't find anything. Thanks in advance for any info,
A.J.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: KZ750 starter clutch
17 Aug 2008 15:40
#232536
You did a search and got nothing? What search terms did you use? This topic is one of the most discussed points about the 750 twin...
:unsure:
How about this:
1.) take off cover
2.) take off left-handed-thread bolt on crank
3.) remove rotor with puller
4.) remove starter clutch assembly
5.) throw starter clutch assembly in trash
6.) reassemble
7.) use kick start
B)
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • Sims426
18 Aug 2008 14:21
#232733
Iv'e tried kicking it, I just don't have enough ass to turn it over fast enough. Where can I get a rebuild kit for it? I wouldn't mind it being kick only though if I knew I could start it:( . I can kick start my 76 750 twin though. Weird.
