Regulator Rectifier wiring
- RSVRDE
11 Feb 2006 18:34
I have a 1980 KZ750H which has been turned into a dirt drag bike. I got this bike somewhat taken apart as the previous owner had dreams of making it street legal again. Anyways there was no reg/rec hooked up (most wiring had been cut. I have one off a 1982 KZ750m1 (supposedly) but from the looks of the wiring diagrams there should be 6 wires? Mine has 5, red/white, yellow, yellow, black, brown. I think that the r/w should go to the battery, the 2 yellows and the black should go to the altenator and I am not sure about the brown. Any suggestions Ideas or info?
- rstnick
Re: Regulator Rectifier wiring
11 Feb 2006 18:54
When I check the wiring dia. for the later 650's, the 2 yellows go to the Generator, the red/white is split going to the battery and the 20 Amp fuse, the black connects to a yellow/black which is the negative to the battery that a lot of other things connect to,and the brown connects to brown that goes to most of the front switches and intrument lights.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rstnick
11 Feb 2006 19:02
Welcome to KZR as well.
Here's the wiring dia. I'm refering to below.
The 6 wire Reg/Rec's have 3 yellow wires that go to the Alternator.
Post edited by: rstnick, at: 2006/02/11 22:07
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- loudhvx
11 Feb 2006 19:03
I think you have a single-phase reg/rec and you need a 3-phase.
80 750 H1 (4cyl): 3-phase stator/reg/rec
82 750 M1 (2cyl): 1-phase stator/reg/rec
Post edited by: loudhvx, at: 2006/02/11 22:15
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- RSVRDE
11 Feb 2006 19:06
I think that you are right. Any suggestions on what I should get?
Thanks,
Joe
Thanks,
Joe
- RSVRDE
11 Feb 2006 19:09
Thanks,
Joe
Thanks,
Joe
- rstnick
11 Feb 2006 19:13
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- loudhvx
11 Feb 2006 19:24
The 4 cylinder '81,'82,'83 KZ 650 CSR (H1,H2,H3) use a 3-phase reg/rec like you need. There's probably many other bikes that can donate a 3-phase reg/rec for a permanent-magnet alternator like yours. Even more modern Ninjas etc. Stick with Kaw or aftermarket ones made for Kaw.
You can sell your 1-phase reg/rec to someone with the following bikes:
1978 650 B2
1978 650 C2 custom
1978 650 D1 sr
1979 650 B3
1979 650 C3 custom
1979 650 D2 sr
1980 650 E1 LTD
1980 650 F1 custom
among others
Rob, you need one?
Post edited by: loudhvx, at: 2006/02/11 22:26
1978 650 B2
1978 650 C2 custom
1978 650 D1 sr
1979 650 B3
1979 650 C3 custom
1979 650 D2 sr
1980 650 E1 LTD
1980 650 F1 custom
among others
Rob, you need one?
1981 KZ550 D1 gpz.
Other links.
Other links.
- RSVRDE
16 Feb 2006 18:42
Just to update, got a 3 phase one at the local salvage the other day and it seems to work fine (only ran the bike for about 60 seconds)I will check it more next week when I get a chance to work on the bike again. One question that I have is what to do with the brown and the black/yellow wires as I have no circuts that would use them. Should they be hooked up somewhere? Also if someone is interested in the single phase let me know, or I will get around to listing it someday.
Thanks for all the input.
- loudhvx
16 Feb 2006 19:42
Black and yellow is usually a ground wire. The brown wire is switched positive. Anytime the ignition switch is on, the brown wire should get battery voltage.
Some models don't use the brown wire, but if your regulator has it, you need it hooked up. If not, you will melt the system.
This is all assuming you are dealing with a Kawasaki reg/rec.
1981 KZ550 D1 gpz.
Other links.
Other links.
