White greese - should I clean all electrical terminals and add white greese?
  • KOOL RYDER
  • KOOL RYDER's Avatar Topic Author
  • KZ 650B2 / KZ 1000E
13 Aug 2008 08:35
#231760
I bought some white greese the other day to rebuild and lube the petcock handle and read that it should be good for battery terminals to prevent corosion.
Is this in fact true and can I add the white greese to the terminals without any worry?
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
  • Locozuna
  • Locozuna's Avatar
Re: White greese - should I clean all electrical terminals and add white greese?
13 Aug 2008 08:40
#231762
dielectric grease
Dielectric grease is a NON-conducting grease that seals out moisture and therefore prevents corrosion on electrical connectors. ;)
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • mtkawboy
  • mtkawboy's Avatar
13 Aug 2008 08:46
#231764
Theres an electrical paste called No-Ox that is made for that. Its what we used at work
  • loudhvx
  • loudhvx's Avatar
13 Aug 2008 08:52
#231768
Grease on the electrical connections causes a mess. I've had to troubleshoot many bikes where the only problem was the owner used dielectric grease on the connections.
  • Locozuna
  • Locozuna's Avatar
13 Aug 2008 09:54
#231772
??? How was the only problem the use of dielectric grease?
Maybe the owner was packing it in with a shovel? :huh: More is definitely not better. I was shown to use just enough to keep the connection from not corroding or building electrolysis. If you are blobing the stuff on ...well ...don't do that!:ohmy:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
  • MFolks
  • MFolks's Avatar
13 Aug 2008 11:46
#231795
A good brand of contact cleaner/preservative (I mention it a lot) is De-oxit made by Caig Labs out of San Diego.
It removes the green crud of corrosion and preserves the electrical contact surfaces. I use it on cordless phone charging cradle contacts,cat 5 cables, and the RCA plug in connectors and sockets of my home entertainment center.
i think you can buy De-oxit at radio shack, anyway the website lists who sells it at : www.de-oxit.com
