Busted My New Electronic Ignition
- ltdrider
11 Feb 2006 14:50
I installed the new Dyna S today. Installation went smooth as silk, and I was getting ready to set the timing.
But when I put a wrench on the shaft nut and turned the engine, my wrench (open end..Doh!) sheared off one of the plastic covers on the points plate. Guess I should have used a socket and extension.
$120.00 shot to hell.
Here's the damage:
Here's the damage:
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- rstnick
Re: Busted My New Electronic Ignition
11 Feb 2006 15:04
That S%#CKS! Can it be repaired?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- Duck
- e vica na i sau na ga
11 Feb 2006 16:15
From photo it looks like it sheared where the plastic is glued to the metal. If this is the case, send email or call the manufacturer, tell 'em what you did, ask 'em what kind of cement to use to fix it.
If you're hell bent on throwing it in the trash, let me take care of that for you
-Duck
-Duck
- ltdrider
11 Feb 2006 16:28
I think the cover holds some of the elctronics, and it is soldered to the circuit board underneath. It would take a better electronics guy than me to fix it.
Duck:
I'll check it out when I remove it from the bike. If it looks too far gone for me, I'll send it to you. I'll send you a PM and let you know.
Duck:
Greensboro, NC
Greensboro, NC
- Duck
11 Feb 2006 16:42
That piece thats held on with what look like cap screws or rivets, kind of mottled cyan on my ancient display, is a circuit board!
It looks like an Aluminum plate in the photo.
-Duck
-Duck
- JMKZHI
Last edit: 03 Dec 2008 20:00 by JMKZHI.
- savedrider
- 1975 Z1-B 900
11 Feb 2006 19:38
JMKZHI wrote:
ltdrider you hamfisted bodger you, what did you do???? j/k man
That's gotta hurt, ego and wallet. Anyhow, I have spoke with Dyna via email a bit and they seem like good folks. See if they might cut you some kinda deal or repair even?
Don't fret about it much though, we've all pulled our tricks - betcha that don't happen twice!
Tell 'em what ya did - maybe they'll send you a replacement. It wouldn't hurt to try. hee.
JMK.
Get right or get left! <*{{{><
- loudhvx
11 Feb 2006 19:48
That thing might still work for someone with a 750 twin or maybe even a 400 twin.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- tfh903
11 Feb 2006 21:09
If Dyna won't take care of you, I'd try some epoxy glue, if you trash it, and if Duck doesn,t get it I call seconds. That's the same side I fried when the regulater crapped.
- SquatchAirClutchSystems
12 Feb 2006 17:29
If you run into a dead end...let me know...i think i have a couple that are not on plates (ie..someone removed them from the main plate) I 'll send one to you. I'm not sure if they are bad or not..
Mike
Mike
- KL250
27 Feb 2006 19:46
loudhvx wrote:
Or me with a 250 single...
- indykaw77
28 Feb 2006 03:23
Might as well give'um a shout or call.....whats the worst they can say, No? Ya never know......
Kawasaki Motorcycles...because cars lean th wrong way!
