KZ750 Twin - Anybody taken off the starter clutch before?
  • kpalm7
  • kpalm7's Avatar Topic Author
10 Aug 2008 10:37
#231152
Hi,
Something in my starter clutch is screwed up on my 1978 KZ750 twin. I've tested the rest of the starter and everything else works fine, the starter clutch simply doesn't move when the chain does. I made a "rotor holder" out of a c-clamp and a few carefully picked bolts, and I've removed the main bolt that goes thru the center of the starter clutch. My question now is how do I get it the rest of the way off? I tried prying a little bit and it seemed like I was getting nowhere so I decided to wait. Am I going to need a rotor puller that screws into the starterclutch assembly and pushes it out or is there another way to remove it?
Thanks for any info, all help is greatly appreciated.
Kevin
  • bountyhunter
  • bountyhunter's Avatar
Re: KZ750 Twin - Anybody taken off the starter clutch before?
10 Aug 2008 13:49
#231191
kpalm7 wrote:
Hi,
Kevin
The FSM says it requires a rotor puller (special tool) to take it off.
  • steell
  • steell's Avatar
10 Aug 2008 13:50
#231192
Why start a new thread? I've already covered this in your original thread.:dry:
