Main fuse keeps burning out
- BLSSeattle
10 Aug 2008 08:22
Hi all. My 79 KZ1300 was running great. I stopped and turned it off to say hi to a friend and all of a sudden when I turn the key the main 30 amp fuse immediately burns right through. I know electrical issues are awful but does anyone have any ideas? I changed nothing and no wires seem to be burnt or touching each other. Any help is much appreciated. With gas prices now I have to have my bike running like she did yesterday. Thanks.
- steve3408
Re: Main fuse keeps burning out
10 Aug 2008 09:27 - 10 Aug 2008 09:31
I'd try looking at wire connections,probably getting a little age on 'em and not making good contact,Especially the headlight it draws power as soon as the key is on,if you have a hi power 80/100 watt headlight and bad connections,it will knock it out quick,especially with the starter drawing power at the same time.Get some sandpaper and roll up little pieces to fit into the connectors and spin by hand to clean up the contact area.Spend some time and go thru the whole bikes connections and do it right.Also get some electrical spray on corrosion preventer for after theyre cleaned.Consider running headlights off of separate relays/wires,check out wiredgeorges upgrades.Also the coils upgrade is great for the older bikes.
1980 KZ1000 A4(bought new),1979 KZ1000 MKII(bought new),1978 KZ1000 A (sold)1979 KZ1000 B LTD (sold)1976 KZ900 LTD (sold)1978 KZ750 twin (sold)
Last edit: 10 Aug 2008 09:31 by steve3408.
- Locozuna
10 Aug 2008 09:30
ditto! Clean all connections!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- MFolks
10 Aug 2008 13:19
After cleaning the connections spritz with some electrical contact cleaner(Not WD-40, Don't ask me how I know!) a good brand is
www.de-oxit.com
- BLSSeattle
10 Aug 2008 13:27
Thanks for all of the info, I'll try it all.
