Spark plug boots and wires.
  • leorider
  • leorider's Avatar Topic Author
06 Aug 2008 13:18
#230546
Is there a way to replace the spark plug boots and wires on my 1978 KZ650? Do I have to buy replacement coils? I just bought this really nice KZ650 and I am hooked on these old bikes. I never thought they could be so much fun. I am used to working on newer twin yamaha. Anyway, if anyone has any info to help me, I'd greatly appreciate it.
Lou
78 KZ650B
  • bountyhunter
  • bountyhunter's Avatar
Re: Spark plug boots and wires.
06 Aug 2008 14:26 - 06 Aug 2008 14:28
#230554
You can buy replacement plastic "boot caps" that screw into the end of the wire. The wires on the kawi OEM coils are molded into the coil. There are wire splice kits to replace the wires outside the coil body.
Z1 has the lowest prices on replacement coils.
Last edit: 06 Aug 2008 14:28 by bountyhunter.
  • Limey
  • Limey's Avatar
  • 3 Years in the U.K. - Brought the KZ with me!
07 Aug 2008 07:32
#230635
I just installed a Dyna-S ignition on my 650 - I replaced the coils with Dyna coils at the same time - and for that very reason, the wires on the old coils are 30 years old!
It is kindof an expensive fix, but IMHO it was well worth the money - the bike runs much better with the all new system, and I don't have to worry about points anymore!
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
07 Aug 2008 08:22
#230640
I agree with what Limey says(well worth it),but if you can't go that route,then you can use these...
NGK SPLICERS
1977 KZ1000 A-1
  • bill_wilcox100
  • bill_wilcox100's Avatar
07 Aug 2008 10:59 - 07 Aug 2008 11:03
#230662
leorider, welcome to the KZR Nation. Great to have you here.
All the advise above is great... just chose the direction that works best for you situation.
Connections are a major part of ride reliability. Save yourself some/lots of time and money and do the WG Coil Repowering Mod ASAP. Don't ask. :blush: See here:
www.wgcarbs.com/index.php?option=com_con...view&id=12&Itemid=26
This is how I did mine:
s259.photobucket.com/albums/hh311/bill_w...lay%20Modifications/
For about $10.00 USD you won't get better bang-for-the-buck.
Best of success. :)
PS
Don't forget to add your year, model and location for the best responses... and can we have a picture of your bike.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 07 Aug 2008 11:03 by bill_wilcox100.
  • bountyhunter
07 Aug 2008 14:00
#230687
If you do want new coils, Z1 has them for $36 each here:
www.z1enterprises.com/detail.aspx?ID=2857
Ignition Coil - 4 Ohm Dual Output - Kawasaki Suzuki
EM24-72451
OEM: 33410-45012 -
Universal 4 Ohm Ignition Coil for Point Ignition - Mounting Points 90mm (3.5") Center-to-Center - Fits Kawasaki KZ900 Z1 KZ1000 1973-78
Fits some Suzuki models and early Honda CB750's
Will fit with other applications with 90mm Mount spacing.
Sold individually - two are needed for 4-cylinder bikes.
Please check bolt spacing before ordering - some Suzuki coils are 4" bolt spacing...
$36.00
