1980 Z1 Classic EFI Accel coils problem
- baja454
05 Aug 2008 22:51
I have a Z1 Classic that I bought 2 years ago to fix up but like my other projects with good intentions... not much has happened with it. It had the Accel coils on it when I got it and I would just like to make sure that they are wired correctly and that the firing order is correct. I got the bike running last summer but it didn't run very good now this year it doesn't want to start and the spark is weak, but what is really odd is when I took out 3 plugs and checking for spark the bike started and ran on 1 plug. It wouldn't take throttle but it started a couple times with just 1 plug in the hole. Without the wiring diagram I don't know what the proper wiring cnfig should be. Can anyone help?
Thanks
Thanks
Re: 1980 Z1 Classic EFI Accel coils problem
06 Aug 2008 01:15
baja454 wrote:
Plugwire routing looks correct, with left coil firing outside plugs and right coil firing inside plugs.
... would just like to make sure that they are wired correctly....
- wiredgeorge
06 Aug 2008 06:16
Your bike has an IC Igniter box somwhere in the area of the battery. This box attaches to the the coils and tells them when to fire. A BLACK wire comes off the IC Igniter and should connect to the coil on the right as you sit on the bike. This is the 1 & 4 coil and the 1 & 4 plug wires should be connected respectively. A GREEN wire also comes off the the IC Igniter and connects to the left coil which is now the 2 & 3 coil and the 2 & 3 plug wires should go to the 2 & 3 plugs. There will also be another small lead which is probably pink or red connected to the other small lug on the Accel coils and this is DC switched power.
