Won't run at night
  • civilengr3
  • civilengr3's Avatar Topic Author
Won't run at night
31 Jul 2008 07:37
#229339
OK I have a '77 650C, which I've had for only a week and haven't had on the road yet, so I don't know much about it.
I got it going the other day after cleaning the carbs and tank of bad gas, and was letting it idle and trying to get that adjusted. Got it running decent (although won't idle low), but when it turned dusk and the running lights came on, I couldn't get it to start, and it backfired.
Could this be electrical related? I checked the points, they are in good shape and gapped properly when open. I am a complete novice when it comes to electrical...
1977 KZ650C
East TN
  • bill_wilcox100
  • bill_wilcox100's Avatar
Re: Won't run at night
31 Jul 2008 07:52 - 31 Jul 2008 10:07
#229346
Hi civilengr3, welcome to the KZR Nation.
The symptoms are telling you that you have a battery and or connector contacts and or charging system fault(s).
Let's get you on the road. A few of the very basic things:
1) Clean contacts in fuse box... even if they LOOK good.
2) Check the battery fluid levels and add distilled water if necessary. And if no change in symptoms, be prepared to charge with a motorcycle charger only or get a new battery.
3) Check and clean the connectors contacts... dielectric grease them if you have it... especially Battery (-) to engine ground.
If this does not help get a Repair Manual and multimeter and be prepared to test/troubleshoot the charging system.
Best of success. :)
BTW, could you add your year, model and location for the best responses.
And, can we get a picture of your new bike?
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 31 Jul 2008 10:07 by bill_wilcox100.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
31 Jul 2008 08:15
#229352
What are these "Running-Lights" you speak of?
Lights that come on automatically at dusk?:huh:
Didn't know any of the KZ's HAD such a feature.
1977 KZ1000 A-1
  • civilengr3
31 Jul 2008 08:37
#229356
Bill, thanks for the list. I will do all those tonight! Plus I'll take a few pics. I've been trying so hard to get it on the road, I hadn't taken any pics yet.
Sandy, yup, it started getting dark out and the tail light and turn signals all came on. I assumed that was normal. Also figured that was too much load for the electrical system, if it's not all clean and whatnot.
1977 KZ650C
East TN
  • Justyn
  • Justyn's Avatar
31 Jul 2008 09:38
#229363
I'm a novice here as well, but from what I know the lights should always be on. I'm not sure about the laws where you are, but in Wisconsin, the lights must always be on, regardless of time of day.
Are you sure the lights weren't on all along, and you just couldn't see them until it was dusk?
I guess either way, I would start by cleaning the electrical contacts. You may have a bad connection someplace, or a lose ground wire or something.
Best of luck.
1980 750 LTD (kz750h) Wausau, WI
  • Locozuna
  • Locozuna's Avatar
31 Jul 2008 09:55
#229366
m m mm mmm mmmaby it'sssss afraid of the d d d dark!! Nope never heard of automatic lights on a bike! Twood be new to me! I have a few not always on lighted bikes but you got to turn them on. Methinks there are other issues afoot!!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • civilengr3
31 Jul 2008 12:07
#229393
Umm, ok. That's weird. The tailight and turn signals came on but not the headlight. I just figured it had a sensor like my Silverado. 'Course, that's an '02; don't think they had that technology in '77. Very weird indeed.:blink:
1977 KZ650C
East TN
  • MFolks
  • MFolks's Avatar
31 Jul 2008 12:30
#229398
The reserve lighting system (a small box uder the seat with 4 wires comming out of it) might be failing or corroded headlight connections in the headlight housing.
  • The Milkman
  • The Milkman's Avatar
31 Jul 2008 13:06 - 31 Jul 2008 22:38
#229408
A 1977 650C model has as seperate headlamp switch on the right control and nothing except the ignition system and charging system is fed any power until to operate a swithch, ie: headlight switch for head and tail light, turn signal switch, or 4 way switch (under the t/s switch, has to be pushed in to turn them on) or either the front brake lever has to be pulled or rear brake pedal has to be pushed for the brake light to come on.
The key has 3 positions,, off to left, on in center and accesories to the right, in the accesory position the tailight comes on and the 4 ways will work the center position is the normal running position.
Make sure you have the key in the center position and all other switches are off to start it and try again.
Last edit: 31 Jul 2008 22:38 by The Milkman.
  • mariozappa
  • mariozappa's Avatar
31 Jul 2008 13:06
#229409
the 77's don't have a reserve lighting system.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • civilengr3
31 Jul 2008 19:59
#229476
Thanks man, I was looking all over for it, and couldn't find it! Now I know why:P
I cleaned up the lectric components as suggested and it ran fine tonight. Hopefully that was it!
Yeah, Milkman, it seems to start and idle better with no accessories on. Which concerns me a little with the idle. Is that normal?
1977 KZ650C
East TN
  • anarki650
  • anarki650's Avatar
31 Jul 2008 20:03
#229477
Check your voltage at the battery when idling. At idle the voltage should be around 12 volts, at 3500 to 4000 rpm the volts should kick up to around 14.5. Readings significantly lower than these numbers mean there's something wrong with the charging system, which could easily explain the crappy idle (not getting enough juice to power all the electrical needs of the bike).
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
