1978 KZ650 - Keep Blowing Main Fuse
- Mountain Rider
27 Jul 2008 18:29
1978 KZ650
Here is the problem. I was adjusting the rear brake light switch to come on earlier, and the main fuse (20A) blew. I checked the nearby wiring visually for any damage (I couldn't see anything) and replaced the fuse. I turned the ignition on and depressed the rear brake pedal a couple of times, and the same fuse blew again.
Any suggestions on where to locate this problem?
- Bluemeanie
Re: 1978 KZ650 - Keep Blowing Main Fuse
27 Jul 2008 19:54
Sounds like a possible short inside the brake light switch to me. Wasn't shorting until you adjusted it, I would try and see if it comes apart and check it out.
- anarki650
27 Jul 2008 20:06
+1 on checking the switch assembly. Also clean up the connections in your fuse box. My 77 kz650 was blowing main fuses left and right because of resistance that had built up at the fuse due to minor corrosion (didn't even look corroded, just dull). I polished up the clips and never had an issue again.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- BSKZ650
28 Jul 2008 08:47
if the wires are run inside the bars, get them out, I had a lot of issues until I removed them and fixed all the bad spots.
77 ltd1000, current rider
76 kz900, just waiting
- KOOL RYDER
- KZ 650B2 / KZ 1000E
28 Jul 2008 09:09
Try resetting the switch to the position it was in before you changed it and see if it solves the problem.
That will either prove or disprove that the switch it the culprit.
If the problem persists then maybe time for a new switch / bebuild.
It may take a few tries, but you will figure it out eventually.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
1978 KZ650B
1979 KZ1000ST
- Mountain Rider
29 Jul 2008 14:29
I replaced the rear brake light switch, installed a new main fuse, and everything seems to be working great.
Thanks for all of your suggestions!
