LED replacement bulbs?
- Sail
20 Jul 2008 06:57
I am 'restoring' a 78 KZ750B and am wondering if anyone has replaced the insturment light bulbs with LEDs? If so what LEDs did you use?
Thanks!
Ken
Thanks!
Ken
1978 Kawasaki KZ750 B3 Twin
- Vter Bob
Re: LED replacement bulbs?
20 Jul 2008 10:10
Check here:
www.superbrightleds.com
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
- Bluemeanie
20 Jul 2008 15:06 - 20 Jul 2008 15:11
Type in "LED Instrument bulbs" in the search box and the results may answer your question. My copy/paste did not work...
Last edit: 20 Jul 2008 15:11 by Bluemeanie.
- Biquetoast
- King Jeremy The Wicked
20 Jul 2008 19:34
Sail wrote:
I was going to do that but I decided that the LED bulbs would be too difficult to see in sunlight (unless you expose them directly, not through the colored plastic). And, probably not worth the expense. I just buy... what is it, 1440's or something? Or 1428's? Whatever they are, they are just typical auto instrument lamps from the auto store for a few bucks.I am 'restoring' a 78 KZ750B and am wondering if anyone has replaced the insturment light bulbs with LEDs? If so what LEDs did you use?
Thanks!
Ken
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- bountyhunter
20 Jul 2008 19:42
Any "LED bulb" that installs in a socket is an LED assembly into a brass lamp base with a dropping resistor built in. That isn't cheap to make, the Luxen 3W LED "bulbs" cost about $25 each now. They are worth it because they save about 15W of power dissipation each. For the small 3W instrument lamps, it's not worth the cost to do it. Just buy a bunch of bulbs. Mine never wear out anyway.
- Sail
23 Jul 2008 15:10
Thanks for the suggestions and comments. I didn't realize that the LEDs didn't 'show' well through plastic. With the tach and speedometer and indicaters taking 10 blubs as well as not being particular easy to change one I had figured that LEDs would be the way to go with my rebuild.
