Jumping Speedo/Tacho
- cluelessone
15 Jul 2008 05:10
Hi Guys,
Hope you can help before I get pulled over for doing 100mph+! How can I stop my speedo/tahco jumping through a range of about 15-20mph/1000rpms?
I've only had the bike a couple of weeks, a 1982 KZ550. Is this something I should just learn to live with bearing in mind the bikes 26 years old?
thanks in advance.
CluelessOne
thanks in advance.
CluelessOne
- Locozuna
Re: Jumping Speedo/Tacho
15 Jul 2008 06:05
Which is jumping, the speedo or the tach? Or Both? Remove cable then remove cable from sheath and inspect. It'll only come out one end. Check the ends especially and then look for fraying. If all looks good. Grease up the cable and slide it back into the sheath and re-install. If not buy another cable. GLuck!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- cluelessone
15 Jul 2008 07:10
Apologies, the original post was a bit ambiguous. The Speedo and Tacho are jumping. Will do as you have suggested.
Many Thanks
CluelessOne
Many Thanks
CluelessOne
