plug wire diagnosis
  • BeeSting
  • BeeSting's Avatar Topic Author
  • Drive it like your tax dollars already paid for it
plug wire diagnosis
11 Jul 2008 15:21
#225608
#1 cylinder isn't firing as far as I can tell (pipe isn't getting hot).
I checked the plug in a different cylinder - no change
I switched coil leads (from the same coil as #1) - no change
What's next? Should I be looking for a certain OHM reading from the #1 wire?
Also, whats the little resistor type thing inside the plug boot?
BeeSting
Flint, Michigan - Chicagoland, IL
If I wasnt such a badass American, I would have to drive a Harley to make up for it
1980 Kawasaki KZ750 H1 LTD (4)
Kurayami (Girl of Darkness)暗闇の女
1980 Honda CX500C - GONE
Christine
  • mtkawboy
  • mtkawboy's Avatar
Re: plug wire diagnosis
11 Jul 2008 16:35 - 11 Jul 2008 16:50
#225617
Put a known good plug on the wire and hold it down against the head, if it fires then Id say the pilot jet is clogged if that plug wont fire in the motor
Last edit: 11 Jul 2008 16:50 by mtkawboy.
  • BeeSting
11 Jul 2008 18:00
#225625
Are the plug caps known to go bad? I checked continuity on the wire and it was good. Checked it on the cap and there wasnt any...
BeeSting
Christine
  • wiredgeorge
  • wiredgeorge's Avatar
12 Jul 2008 08:25
#225699
What do you mean by a plug cap? Resistor in the cap? There shouldn't be one. My definition of a plug cap is the part that contacts the spark plug (clips on) and is covered by a rubber shroud to keep weather off. Take the #1 spark plug lead WITH cap and put it on the #4 spark plug. Take the #4 spark plug lead with cap and put it on the #1 spark plug. Does the #1 cylinder continue to non-fire? If so, remove the #1 spark plug and REPLACE WITH NEW SPARK PLUG and repeat test. To test the cylinders for firing, the BEST way to do it is to use pump-spray bottle with water and spray the exhaust header once the bike is warmed a bit. A firing cylinder will VAPORIZE the water and a non-firing will spit and sizzle but the water will bounce or drop off.
  • mtkawboy
  • mtkawboy's Avatar
12 Jul 2008 09:15
#225706
I recently ohmed all my original plug caps, about half showed open the rest showed around 5 ohms. I dont think they should open open should they ?. It also helps to trim back 1/4 inch of the wire to get fresh copper to screw them into
  • Stargate
  • Stargate's Avatar
12 Jul 2008 12:57
#225728
I think the normal reading for a resistor cap is 5k ohm. If it reads open then you aren't going to get any spark no matter what plug you put in it. I removed the resistor caps and just use a wire with a plain rubber boot on the end to cover the plug.
1981 KZ1000-K1 LTD
Original owner
Photos
  • mtkawboy
  • mtkawboy's Avatar
12 Jul 2008 14:53
#225749
I hear you stargate , my good ones were 5 ohms but the bike ran on open caps and open plug wires which I still dont understand. Not real well, but it did run. Just did my second Wg coil mod, that is the nuts !
  • BeeSting
12 Jul 2008 16:52
#225758
I replaced the plug cap and after a few other obstacles it seems to be running well. I just need to get the exhaust gaskets and then I'm set (until next time).
BeeSting
Christine
