Spark Plugs - B7ES B8ES or B9ES
- KOOL RYDER
- KZ 650B2 / KZ 1000E
10 Jul 2008 09:15
OK - which spark plug is the coolest and what sparkplug is the hottest? 7 or 9 ?
I just changed from B8ES to B7ES and noticed a difference.
The difference being a deeper sounding engine that responds more at lower RPM's, but does not run as smooth as the B8ES at 60 MPH.
Is this common?
When I removed the B8ES they were sooty and chared with black carbon deposits, is this an indication of oil getting past the rings or just a sign of old age?
Please comment on what spark plugs you use. Does anyone run the B9ES?
What effects can spark plugs have on the engine?
Thanks
Is this common?
Thanks
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
1978 KZ650B
1979 KZ1000ST
- PLUMMEN
Re: Spark Plugs - B7ES B8ES or B9ES
10 Jul 2008 09:25
number coresponds to length of insulator smaller number is hotter plug.
- mtkawboy
10 Jul 2008 09:39
Which isnt your problem, it should run on B8's
- Saki Jockey
10 Jul 2008 10:59 - 10 Jul 2008 10:59
Try ND W24ES/U. Far superior plug.
Rob A.
550 A4
GTA,
Ontario, Canada
550 A4
GTA,
Ontario, Canada
Last edit: 10 Jul 2008 10:59 by Saki Jockey.
10 Jul 2008 11:46
Would mostly rely on using factory recommended sparkplug (B8ES) for most of us under normal riding conditions using the full rpm range in a mix of city and highway riding.
Hotter sparkplug (B7ES) runs hotter to help keep plug cleaner and avoid carbon loading under conditions of sustained lower rpm usage such as plonking around town all the time without some regular higher rpm usage (such as an occasional hard acceleration rip through the gears to "blow it out.") The original Z1 Owners Manual said B7ES could be used during the break-in period if B8ES plugs were fouling, but cautioned in bold print to use B8ES after break-in because continued use of B7ES for hard acceleration or high speed could cause engine damage from overheating. The FSM warns further about preignition and burning holes in pistons.
Colder sparkplug (B9ES) runs cooler at sustained hard high rpm usage such as extended high speed operation or road racing to help hold the temp about where it would be with a B8ES under more normal operating conditions. The original Z1 Owners Manual said B9ES could be used for cooler running if ceramic on B8ES plugs was burning white. The FSM warns further about several additional problems caused by carbon build-up on the colder plugs.
Where non-defective properly gapped B8ES plug readings are too dark or too light, it's almost never the plug's fault. But more likely a problem with the ignition, timing, compression, or carbs.
Good Luck!
Good Luck!
- FastKaw1
10 Jul 2008 11:55
You didn't say what you are putting the plugs in.
But from what you said you have more then
a spark plug problem.
If your bike calls for B8 putting (colder) B7 will not help.
Putting a B9 (hotter) might but only for awhile.
Your bike has some other issues that should be addressed.
Do compression/leak down test.
How many miles on the motor?
Or it could be something as simple as real dirty air filter.
XENU
XENU
- mtkawboy
10 Jul 2008 13:32
Check voltage going to the coil, ohm primary & sec side of coils, ohm resister plug ends, check point gaps & condition
- steell
10 Jul 2008 14:50 - 10 Jul 2008 14:55
Here you go, all you (never) wanted to know about NGK spark plugs.
www.ngksparkplugs.com/techinfo/spark_plugs/techtips.asp?nav=310
Patton has it exactly right
Last edit: 10 Jul 2008 14:55 by steell.
- FastKaw1
10 Jul 2008 19:50
Great web page
Learn something new ever day.
Thanks
Thanks
- galaxian
11 Jul 2008 05:43
Whats interesting is that the NGK website lists the B7es as the recommended plug for the 1979 650c and my manual says use the 8 for normal use and 7 for city use.
Great info!!
Great info!!
1977 KZ1000A1, 1979 KZ650 C3
- KOOL RYDER
11 Jul 2008 09:19
So would the gap on the plug out of the package be fine to use or should I be increasing or decreasing the gap of the plugs?
What is the correct spacing of the B8ES plugs for a KZ650B?
1978 KZ650B
1979 KZ1000ST
1978 KZ650B
1979 KZ1000ST
- TheTrout
11 Jul 2008 10:59
I would run the recommended plug and then do the WiredGeorge coil mod. Good chance this is why your plugs are black and sooty.
1978 KZ1000B2
The following user(s) said Thank You: tdogm6@yahoo.com
