78 KZ-650-C2 only firing on #1 and # 4 cylinders ???
  • Tower_Monkey1
  • Tower_Monkey1's Avatar Topic Author
08 Jul 2008 18:01
#224984
Just put in a new battery,carbs cleaned,dyna ignition,dyna coils,4 to 1 header. Bike started but was only running on #1 and #4 cylinders. Put in new plugs and problem didn't go away. What could the problem be ? I checked the coil wiring and it seems fine. Have silicone plug wires from coils to plugs. If you pull one plug wire off a little it will fire on the corresponding plug from that coil. Im at a loss and hope you guys can come up with a solution... Thanks Wayne
78 KZ650C2 Dyna ignition and coils,Pod filters,4-1 Kerker,CBR Tail Light,Drilled front dics,Custom front fender,1/4 fairing.
  • Bullitt03737
  • Bullitt03737's Avatar
Re: 78 KZ-650-C2 only firing on #1 and # 4 cylinders ???
08 Jul 2008 19:06
#225005
Sounds like that coil is bad. Do you have another you can swap in to double check?
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
  • anarki650
  • anarki650's Avatar
08 Jul 2008 20:48
#225037
You said if you pull a plug wire off you get spark, are you talking about the 2/3 wires or the 1/4 wires? If you're not getting fire on the 2/3 cylinders I'd check the coil. Is the dyna a new installation? Has it run on all 4 before now? If so, what has changed?
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • Tower_Monkey1
09 Jul 2008 03:04
#225087
Nothing other then the new battery. I dont have coil's to change out with. #1 and #3 are one one coil and #2 and #4 are on the other coil. Dyna was installed last year and ran great. If I pull #1 off , I get spark to #3 and vise versa with #4 .Like I said battery is new as of the 7th of this month and fully charged.
  • bill_wilcox100
  • bill_wilcox100's Avatar
09 Jul 2008 03:32 - 09 Jul 2008 03:36
#225089
Have you swapped the coils to see if the symptom follows the coil? If it follows the coil could be a bad coil or associated plug wires. If it does not follow the coils then could be a coil power or points problem.
Are the affected plugs showing black soot? If so,...
Have you cleaned/replaced the contacts for the coil power?
Have you done the WG Coil Re-powering Mod?
If not consider swapping the points and associated capacitor (condenser).
Best of success!
Sorry, just noticed the Dyna upgrade... forget about the points but throw away the Dyna crimp-on connector and solder the wires then protect with heat shrink tubing.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 09 Jul 2008 03:36 by bill_wilcox100.
  • steell
  • steell's Avatar
09 Jul 2008 04:57
#225093
Hmm, it's supposed to be 1 & 4 on one coil and 2 & 3 on the other coil. Might run better if the coils were running the right cylinders :)
  • Locozuna
  • Locozuna's Avatar
09 Jul 2008 05:18
#225094
Sounds to me like he has the wires right...
See if there is any arcing.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
09 Jul 2008 09:02
#225143
As steell says, one coil fires outside plugs #1/4. And the other coil fires inside plugs #2/3.
Plugs are numbered starting on the left (gear shift) side of the engine.
Good Luck! :)
  • mtkawboy
  • mtkawboy's Avatar
09 Jul 2008 09:27
#225152
Went thru the same thing yesterday, 2-3 coil checked good on primary & secondary side but bike wouldnt run on it. Swapped one from my other Z1 and it ran perfectly. Still dont understand it
  • Tower_Monkey1
09 Jul 2008 13:58
#225211
Oppsssss my bad, it is #1 and #4, #2 and #3. Maybe the #2 and #3 coil is the problem.. Hmmm I guess I'll start with taking the wiring apart and go from there...
09 Jul 2008 14:35
#225213
If not already done, would remove plugs and inspect spark on each plug as engine is cranked over with ignition switch on.
Seeing spark on the removed plug is a fair indication that it's also sparking when installed.
Good Luck! :)
  • Tower_Monkey1
14 Jul 2008 11:22 - 14 Jul 2008 15:57
#226098
Today I checked the coil for #2 and #3 cylinders with a test light and got power at both terminals. I did the same test on coil for #1 and #4 and only got power at top terminal. I pulled the coil for #2 and #3 cylinders and did a check with a Ohm meter and got 4.1 Ohm's between primary leads. It should be 2.9 - 3.2 Ohm's. I checked the secondary and got 14.8 K . It should be 13.5 - 14.5 K . I then tested the coil for #1 and #4 and got same reading on Ohm meter. Put the #1 and #4 coil back in place of #2 and #3 coil and vise versa with other coil. The problem DIDN'T follow the coil swap. I then pulled the point cover and checked the Dyna ignition and found that if I wiggle the pickup for #2-#3 coil I can get it to work. Hmmm it feels as thought that pickup box has gotten hot and the cover is very loose. I will have to get with Z-1 enterprise and see if I can get one new Dyna ignition pickup for the #2 - #3 coil side. Dang it !!!
Thanks for all the help guys... Wayne
Last edit: 14 Jul 2008 15:57 by Tower_Monkey1.
