coil testing
  • Becker
  • Becker's Avatar Topic Author
  • The Doctor Will Rise Again
coil testing
08 Jul 2008 12:06
#224915
I have been trying to get my KZ400 H1 started and I was having problems with spark. I tested the coil and it shows 3.2 ohms across the terminals and 14,200 ohms across the spark plug wires. I think this is within spec, but my question is can I now rule out the coil and move on to other possible problems or can there be something else wrong that I can't test for?? Also do I use the non resistor type spark plug boots or do I use the resistor type?? I want to buy new ones since these are shot. Thanks in advance for any advice.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • bountyhunter
  • bountyhunter's Avatar
Re: coil testing
08 Jul 2008 12:33 - 08 Jul 2008 12:34
#224923
It should work with either resistor or non resistor. The nons should give a bit more spark voltage.
A coil may be arcing internally from the high voltage which would not show up on your meter test.
FYI, I believe Z1 sells new coils for the twins for about $36 if you do need one.
A flaky condenser or points can cause a weak spark also.
Last edit: 08 Jul 2008 12:34 by bountyhunter.
  • Becker
Re: coil testing
08 Jul 2008 15:07
#224958
Well I guess I'll just assume its good for now and order a new coil. maybe I can track down something somewhere else. Thanks for your help though.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
