kz650 CSR H1 Grinding noise from starter area.wont start
- nagrom68
04 Jul 2008 11:00
Just Bought Bike , Has new Battery and just had starter rebuilt.When I try to start in turns over 1 to 2 times then makes this grinding Noise From Starter area. anyone have any ideas?
- RetroRiceRocketRider
Re: kz650 CSR H1 Grinding noise from starter area.wont start
04 Jul 2008 11:55
Welcome to KZr nagrom68.
Sounds to me like your starter clutch is the culprit, which seems to be a common wear item in the KZ650/KZ750 engines.
It's not that involved of a repair to remove and rebuild it (the replacement parts are readily available), and the plus is that the engine does NOT need to be pulled from the frame to do this.
If you do a search in the KZr archives under "starter clutch", there's a really good step-by-step thread with pics posted by OnkelB in there that should be able to walk you through it.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- nagrom68
04 Jul 2008 15:43
Thanks, Will check it out .Thanks
