Would a bad coil blow main power fuses?
  • Qdude
  • Qdude's Avatar Topic Author
  • It is all good.
03 Jul 2008 14:44
#223793
My bike suddenly started blowing fuses today.
It was raining very hard.
I had little time and simply had to go a little further, so I took a calculated risk. I jumped the fuse.
The bike ran another 2 miles then stopped sparking, at the same time the idiot lights became dim.
There were smoke wisps from under the tank.
The power wire, running through the fuse up to the ignition switch, did not look heat stressed.
I recently put in a Dyna ignition and apparently there are issues with matching impedance to the coils.
I believe that I fried a coil.
Any thoughts?
77 KZ 650 C1.
77 KZ 650 C1.
  • Qdude
  • It is all good.
Re: Would a bad coil blow main power fuses?
08 Jul 2008 13:36
#224939
It was water.
The connectors got doused and caused shorts. It is all up and running now. Close call.
77 KZ 650 C1.
77 KZ 650 C1.
  • MFolks
  • MFolks's Avatar
08 Jul 2008 21:37
#225052
I've posted before about using a very good electrical contact cleaner/preservative called De-Oxit made by Caig labratories in San Diego Ca. Try it as it will improve all electrical conductivity (motorcycle connectors,cell phone charging connections,cordless phone charging bays, etc)
www.deoxit.com
www.caig.com
I do not sell the stuff just a very satisfied customer!
  • bountyhunter
  • bountyhunter's Avatar
08 Jul 2008 22:01
#225059
You can also use silicone grease to seal off connections that are arcing down and causing failures if necessary.
  • Qdude
  • It is all good.
09 Jul 2008 16:05
#225224
Thanks all.
77 KZ 650 C1.
77 KZ 650 C1.
