electrical problem
- sdw25
electrical problem
02 Jul 2008 08:39
I have been trying to get my bike going and have upgraded the ingnition to dyna s and wired the coils according to wgcarbs tech the fuse to the relay ugrade is also blowing when the bike cranks and runs but the headlight will not come on and now the taillight has stopped coming on also it has the original wiring harness any help is appreciated
dale
crandall,ga
78 kz650 sr emgo pods 4 into 1 exhaust
crandall,ga
- OKC_Kent
Re: electrical problem
03 Jul 2008 10:06 - 03 Jul 2008 10:11
It may be your fuse box, take a look at it. Are the three fuse clips tarnished, corroded? You can replace that fuse box with a new style that uses the new blade style fuses. This may be all it needs.
You can use these:
or this:
Also make sure the connections in the white square are very clean. Corrosion in this plug coming from the regulator/rectifier will add lots of heat and put bad juju into your system. Don't ask how I know this.....
You can use these:
or this:
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Last edit: 03 Jul 2008 10:11 by OKC_Kent.
- sdw25
03 Jul 2008 17:50
thanks for the help I try a few things and let you know how it turns out
dale
crandall,ga
crandall,ga
- sdw25
05 Jul 2008 18:08
headlight had some corrosion and cleaned up also had a wire not hooked up properly for wgcarbs coil upgrade and had a bad bulb in tail light thanks for your help:)
dale
crandall,ga
crandall,ga
