headlight flickered off/on now not working at all
  • rctigers
  • rctigers's Avatar Topic Author
01 Jul 2008 17:55
#223370
I have a 1978 KZ750. One morning, on my way to work the headlight would go off and then come back on (off/on). All other lights are working fine. I removed the headlight and
had sporadic voltage on the headlight connector. Checked the connections inside the headlignt bracket. They seemed tight. Don't know what to check next. Also the headlight only comes on after I start the bike. The other lights come on when I turn the ignition to on. Anyone go any ideas?
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: headlight flickered off/on now not working at all
01 Jul 2008 18:02
#223372
Have you tried it on high and low beam?
Does it make a difference?
How does the high-beam switch feel when you switch it?Can you feel it,"Click" when you switch it?
Might be time to grab a 12volt test-light,and start wiggling some wires around inside the headlight bucket.
And it COULD be a sign that the headlight itself is on it's way out...try a different bulb.
1977 KZ1000 A-1
  • Saki Jockey
  • Saki Jockey's Avatar
01 Jul 2008 18:26
#223378
Theres a slick little device called the emergency lighting something or other. If you've got a manual, I'd read up on it before going further. Sorry I don't have more detail.
Rob A.
550 A4
GTA,
Ontario, Canada
  • MFolks
  • MFolks's Avatar
02 Jul 2008 19:49
#223628
The device mentioned above functions to have the high beam come on at a reduced voltage to allow you to drive(no bright high beam though)in the case of the low beam failure.
Check the wiring from this box as the connectors get corrosion in them and quit working.
  • steell
  • steell's Avatar
02 Jul 2008 20:11 - 02 Jul 2008 20:14
#223634
Um, not on a 78 750 twin there isn't, and a 78 KZ750 can only be a 750 twin :)
Why does the headlight go on when you start the bike? There's an on/off switch for the lights on the right control pod on the 78 750 twins, they removed the switch but left the hole for it on 79 models.
Last edit: 02 Jul 2008 20:14 by steell.
