front turn signal wont blink, and rear wont work?
  • TotallyTitties
  • TotallyTitties's Avatar Topic Author
25 Jun 2008 20:51
#222216
now I can easily change the bulb on the back. but anyone know why it might not be blinking?
  • idkrash
  • idkrash's Avatar
Re: front turn signal wont blink, and rear wont work?
25 Jun 2008 21:42
#222223
Turn Signal Relay's (AKA winky deals) have corroded connectors, the wire is too old to carry current right, or relays are bad.
Remove relays. Sand connectors. Reconnect.
or
Wires too old.
Remove relays. Clip off about 1 inch of wire. Reattach old slide on connector to "new" end of wire. Reconnect.
or
Buy new relays and replace the old ones.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
25 Jun 2008 21:44
#222225
Bad flasher...bad ground-wire somewhere?
Corroded bulb socket?
In case you didn't know...the REAR lights do NOT light up as markers...they are a single filiament bulb,and only flash for signals.
The fronts are a dual-filiament bulb and they DO light up as markers,as well as signals.
1977 KZ1000 A-1
  • KOOL RYDER
  • KOOL RYDER's Avatar
  • KZ 650B2 / KZ 1000E
25 Jun 2008 23:15
#222240
check your rear ground as well and make sure you do as stated above.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
