Starter bearings, bushings. Pulling, Pushing.
  • idkrash
  • idkrash's Avatar Topic Author
25 Jun 2008 20:46 - 25 Jun 2008 21:32
#222214
I've pulled the starter apart and want to replace the bushings and bearings with the ones that came in the rebuild kit.
Can I stop by the local Norther Tool store and pick up the tool I need to get these things (1, 3, 4) out and ram the replacements in? I'm willing to spend about $35.00.
Also what is that pin at #2, and should I just leave it be? I hope I don't have to drill that out to get the shaft out and replace the bearing and seal.
I tried to knock out the shaft at #4 with a block of wood and a hammer but it didn't seem to move right away so decided to ask about how to do it right.
Big Photo Starter end caps
Here is the exploded drawing I'm working from.
Larger Image
Last edit: 25 Jun 2008 21:32 by idkrash.
