Turn signal indicators on instrument cluster flash opposite ! ? !
- Max
24 Jun 2008 09:39
Hi All,
Is there an easy fix to my '80 KZ750 E1's turn signal indicators on the instrument cluster that indicate the opposite way the actual signals are flashing? When I push the lever to indicate a right turn the right flashers indicate correctly but the istrumnet cluster indicators show a left turn and vis versa.Any ideas?
Thanks,
Josh
Thanks,
Josh
- Oznative
Re: Turn signal indicators on instrument cluster flash opposite ! ? !
24 Jun 2008 10:49
Someone must have swapped the bulb sockets around in the console. Just open the console and swap the socket and bulb around.
1977 KZ1000 A-1 Just north of Boston
- Max
24 Jun 2008 11:19
Is the "console" the handlebar housing or is it in the instument cluster? Thanks, Josh
- wiredgeorge
24 Jun 2008 14:08
The console he refers to is likely the one where the idiot lights are located. There is a small wiring harness going to the stuff in your... let's call it your dash board... he thinks the bulb holders were removed and reversed. I am not sure if that is possible or not as I am not all that familiar with your bike but you could take the bulb holders out, if they can be removed and swap them (in the dash board).
- HerrDeacon
25 Jun 2008 03:37
The same thing is happening to mine now. I had mine all apart this winter and I think I must have swapped the bulbs by mistake when I put it together.
I'm going to leave mine for the time being and probably fix this coming winter.
