igniter or pick up bad?????
- zombiescustoms
18 Jun 2008 17:57
Well I tried to slot my pick up coil plate to get a little retard in my timing to try and cure my detonation issues, took everything off the plate enlarged the holes, put back on and runs a little better but I still think I need a little more, so i take it back apart and make the slots a little longer, and now no spark and no run!!! checked the coils they have juice going to them, pick up coils both have about 450 ohms as per clymer, so im thinking i need a new igniter, or should I just go with a dyna S, I already have the dyna 3 ohm coils.
HELP!
HELP!
1979 KZ1000 drag/street fighter
1015cc stock internals for now, 39 flattys, GSXR frontend, ZX9 rear wheel with 6 over chromoly arm, just a budget beater!
- John Simons
- zombiescustoms
Re: igniter or pick up bad?????
18 Jun 2008 18:32
John Simons wrote:
Just as I stated no spark and it won't run now, ran fine and 10 min. later after I reassembled the pick ups, nothing.
What are your symptoms
- Sandy
- Fly High,Tony
18 Jun 2008 20:42
Check the kill-switch...or is the engine turning over?
1977 KZ1000 A-1
- zombiescustoms
19 Jun 2008 03:11
Its turning over just fine, I'm leaning more twards the ignighter, and think I'll just replace the whole thing with a dyna set up.
- loudhvx
19 Jun 2008 06:42
When you slotted the holes, did you take the magnets and pulsers off the timing plate? If so , it's possible you put the magnets on wrong. I have a thread here somewhere showing how to put the magnets back on correctly.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- zombiescustoms
19 Jun 2008 09:21
loudhvx wrote:
yes I did that is my next thing to try
- zombiescustoms
19 Jun 2008 16:06 - 19 Jun 2008 16:06
Thanks loudhvx, it was the magnet, I was able to find your pics and description of how they are installed, bike started right up!!!
next I need to see if I have it retarded enough to curb my detonation issues.
Last edit: 19 Jun 2008 16:06 by zombiescustoms.
- loudhvx
20 Jun 2008 02:56
1981 KZ550 D1 gpz.
Other links.
Other links.
