Throttle assembly
- violentvintagecycles
Throttle assembly
17 Jun 2008 12:29
One last thing im looking for thats pretty important.. 82 KZ550a3 throttle assembly, or the GUTS to it? 6 pin connector.
- BSKZ650
Re: Throttle assembly
17 Jun 2008 13:50
the sad thing is unless you find a good one at a bone yard, you will be stuck with flebay
77 ltd1000, current rider
76 kz900, just waiting
- steell
17 Jun 2008 15:12
Looks identical to the one on a 79-80 750 twin, so you might check the parts diagrams at kawasaki.com and see what models share that part.
- Saki Jockey
17 Jun 2008 18:06
check with andy the gringo or loudhvx.
Rob A.
550 A4
GTA,
Ontario, Canada
550 A4
GTA,
Ontario, Canada
18 Jun 2008 01:57
Andy, Gringo, Lou, you out there?? :laugh:
Steel, that was a great idea, checked Kawa, finally figured out how to do that. Anyway, if anyone has a throttle assembly for one of these bikes and looking to find it a good home...
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-A4 (1983)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
KZ750-H4 (LTD) (1983)
Ill be checkin ebay too. Thanks all
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-A4 (1983)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
- wiredgeorge
18 Jun 2008 06:39
That thing you are showing in the initial post doesn't likely come off an 82 bike. It has an on/off switch for the headlight. I think by 82, the headlight doesn't have an on/off switch. It looks like a KZ900 switch except instead of on/off, it is ON / PO / OFF where the PO is for parking lights or something (can't recall).
- Sandy
- Fly High,Tony
18 Jun 2008 08:41
wiredgeorge wrote:
A lot of the controls have the opening for the switch,but most are just capped off.
Take one apart,and there is a place to mount the switch,but there's no wiring for one.
1977 KZ1000 A-1
18 Jun 2008 18:16
It had chopped up parts from a gpz harness when i first got it. THINK the reg/rec if from a gpz, it thes only thing on the new harness that didnt match up. (2 female connectors). So i wouldnt be surprised if it was from a honkasuzyaha. It worked oddly enough, right connector to the harness too.But the no start button thing is killing me. I have it rigged up to a simple auto parts push button switch, but i dont want to rig anything, id like to see the right part on there. Think i found one, will know tomorrow, but would still like to keep it in the family so to speak.Its coming together nicely too, keep meaning to post pics, but..
