Moisture in Speedo
  • dshelly
  • dshelly's Avatar Topic Author
Moisture in Speedo
16 Jun 2008 15:34
#220378
Hi all, I was just wondering if anyone knows : can you get the moisture out of a speedo and tack? Doesn't look like you can get them apart. Mine has some moisture behind the lens and I would like to dry out /clean them . any info?
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • violentvintagecycles
  • violentvintagecycles's Avatar
Re: Moisture in Speedo
16 Jun 2008 16:44
#220391
try heating the glass with a blow dryer.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
16 Jun 2008 19:41
#220424
A blow dryer with the backside (with holes) up to let out the moisture might just work.
Otherwise you can take them apart, but it's not an easy task.
You have to carefully uncrimp the center band and separate the halves.
It could be worse. You could've had a Spider in there, with web, that stopped the needle from passing 60KPH like mine:
Before:
After, with ring painted blue:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • wiredgeorge
  • wiredgeorge's Avatar
17 Jun 2008 06:51
#220476
dshelly, You can open up the speedometer and clean it just fine.
see:
kzrider.com/index.php?option=com_content...view&id=39&Itemid=11
