Turn Signals
- Marc
Turn Signals
09 Jun 2008 06:29
I have a 1974 Z1 900 and I replaced the original bulb style turn signals with LED style turn signals. They all light up and work but they do not flash. What is the problem? Do I need a flasher module? What's the deal? Can anyone help?
- Sandy
- Fly High,Tony
Re: Turn Signals
09 Jun 2008 07:29
Do you even HAVE a flasher installed,or are you asking if you need to REPLACE the flasher?
Start there,and try installing a new flasher.
I too,have all L.E.D. signals,and they all work perfectly,using the same flasher that I was using with the other signals.
1977 KZ1000 A-1
- bountyhunter
Re: Turn Signals
09 Jun 2008 13:45
If you have a traditional (bi metallic) flasher, LED's will not make it flash. The current isn't high enough to heat the metal and make it bend. The LED places sell electronic flashers which will work with LEDs.
- unkle fester
Re: Turn Signals
09 Jun 2008 19:10
Auto-Zone, Advance Auto, O'Reilly...any parts place will have an electronic flasher....about 10 bucks...I used one when I went with an integrated taillight.....
- Marc
Re: Turn Signals
10 Jun 2008 05:00
Sounds good and thanks for the help. I am using the original Z1 flasher. There is an Auto Zone in town so I will check them out. Is there a specific module I need?
- Marc
Re: Turn Signals
10 Jun 2008 05:02
I am using the original flasher which works with regular buld turn signals but not the LED. What do I need?
- Marc
- unkle fester
