Ignition Turning off, But coming right back on...
- Bullitt03737
07 Jun 2008 13:08
Occassinally when I go to start the ol KZ the ignition will turn on fine. And sometimes it will all just shut off, headlight and all. I switch the key to off and back to on and everything is fine. Im wondering if this has anything to do with my surging that happens on the highway. What should I check out to maybe narrow this down.
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- RetroRiceRocketRider
Re: Ignition Turning off, But coming right back on...
07 Jun 2008 14:13 - 07 Jun 2008 14:15
I'm fairly certain that it's the same on the old style (pre-1979/1980) KZ ignition switches, but on the new style switches there are brass(?) contacts on the bottom of the switch under the cover that wear/lose their tension and will ocassionally cut power to the bike.
My ZN700 has this problem.
A slight (approximately 1/8" ) turn of the key counter-clockwise restores power and I'm on my way again. I cleaned the contacts and it worked great for a while, but I'm guessing the contacts have lost their tension and aren't touching consistently since it's acting up again = time for a new ignition switch.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
Last edit: 07 Jun 2008 14:15 by RetroRiceRocketRider.
- Bullitt03737
09 Jun 2008 20:16
I looked over the obvious stuff. The negative terminal was about three threads into the nut. All seems well now..
