Electronic ignition question!
  • badrhino
  • badrhino's Avatar Topic Author
06 Jun 2008 12:19 - 06 Jun 2008 12:31
#218381
I do believe that this is an electronic ignition system. There is one wire that is not connected. The wire that is not connected is Blue with a pink stripe, can anyone tell me what wire this is and why it is not connected or does it not need to be connected.Also, I am going to put on new plug wires, any suggestions wich are best.7mm8mmCopperSuppressors ???????????????Yet another question, what Coils are best?????????????
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Last edit: 06 Jun 2008 12:31 by badrhino.
  • badrhino
Re: Electronic ignition question!
06 Jun 2008 12:52 - 06 Jun 2008 12:53
#218390
I have tried to post pics. on here but nothing is working. The file size is within range and nothing!Any suggestions?
Franken Z!
Last edit: 06 Jun 2008 12:53 by badrhino.
  • badrhino
06 Jun 2008 13:04
#218393
Did it finallyshow up?
Franken Z!
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
06 Jun 2008 16:06 - 06 Jun 2008 16:07
#218414
On a kz650 that's the Oil Pressure switch's wire, which is located behind the pick up plate at 6 O'clock.
I don't think a kz1000 has this pressure switch, in which case I bet your pick ups are off a 650/750, which is OK. They will work fine. Just don't need the extra wire.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 06 Jun 2008 16:07 by rstnick.
