Still troubleshooting a Turn signal issue
- KOOL RYDER
- KZ 650B2 / KZ 1000E
04 Jun 2008 08:16
Status:
Left blinkers not working. If I turn on the right blinker it work fine, then when I switch the left blinkers on, I hear it make 1 dink sound, maybe 2, 3 or 4 but no lights come on and then the rely stops making any sound at all.
I check the switch and there is power.
I replaced the flasher relay, but one of the leads that connects to the flasher is broken.
THe back piece of the lead came off. Is his my problem?
Any suggestions would help.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
1978 KZ650B
1979 KZ1000ST
- rstnick
Re: Still troubleshooting a Turn signal issue
04 Jun 2008 14:30 - 04 Jun 2008 14:31
Swap bulbs with the right side, as you know they work.
Fix that lead to the relay.
If your using modern turn signals, not old Kawi ones, you'll need a modern electronic signal relay. You can get them for under $10 and they're a dirrect plug in.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 04 Jun 2008 14:31 by rstnick.
- RonKZ650
04 Jun 2008 15:16
If you're just talking about plastic backing coming off the lead, that's not a problem. Of course the contacting wiring and connectors must all be intact to work. You are replacing the right relay I assume? In 78 they had 2 flasher relays, one for hazards, one for blinkers.
- bountyhunter
04 Jun 2008 15:25
In nearly all cases, the flasher unit is common to both sides: it is in the power line coming to the switch which selects left or right. If one side flashes properly, the flasher is good. The wiring through the flasher to the center of the switch is good. If it fails to flash on one side, it means there is not enough current load on that side to work the flasher, usually, a single blown bulb will do this. An open connection will too. If either bulb is not connected or doesn't have wire continuity, the flasher won't flash.
