Ignition Coils from different bikes
  • aussiebrad 81 kz750ltd
  • aussiebrad 81 kz750ltd's Avatar Topic Author
05 Feb 2006 17:52
#21743
Hi does anyone know if ignition coils off a 81 KZ550 would be the same as the coils used on a 81 KZ750.
Thanks: Brad
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Ignition Coils from different bikes
05 Feb 2006 18:14
#21751
They do have different part #s when I look them up here
but that does not mean you cannot swap them. I'm not sure if you can though.
Here are the 2 diagrams with the part #s:
Post edited by: rstnick, at: 2006/02/05 21:16
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • wireman
  • wireman's Avatar
05 Feb 2006 19:01
#21762
as long as the voltage and ohms rating are the same i dont see any problemB)
  • loudhvx
  • loudhvx's Avatar
05 Feb 2006 22:51
#21808
True.
But points coils will have different ohms than the electronic ignition ones. The electronic-ignition-coils will wear points faster than points-coils. If the 750 has electronic ignition, then it's not an issue.
(Some 550's had electronic ignition in 1981.)
Post edited by: loudhvx, at: 2006/02/06 01:54
05 Feb 2006 23:26
#21814
Thanks for all your information the diagrams with part numbers are great I have added the link to my favorites.
The coils are actually off a 82 550LTD I plan on putting them on my 81 750 LTD. I assume the 82 550 LTD would have had electronic ignition?
Anyway I thik I will buy them and give them a go.
Cheers: Brad
  • wiredgeorge
  • wiredgeorge's Avatar
06 Feb 2006 07:23
#21866
I would check the primary resistance. They will be either 3 ohms or 1.5 ohms. To check, measure between the two lugs that you hook power and the ignition wire to. The reading should be the same as the coils you are currently using or what the reading should be for your bike.
  • loudhvx
  • loudhvx's Avatar
06 Feb 2006 11:37
#21924
Points coils will be around 4 ohms, and electronic igition coils will be around 2.5 ohms.
