Coil questions
  • riverroad
  • riverroad's Avatar Topic Author
  • 1980 1000LTD B4
Coil questions
02 Jun 2008 11:50
#217426
Can somebody help me with what coils will fit on my bike?
My 1980 has electronic ignition with what I believe to be 3 ohm coils.
Been looking at E-Bay and there's some for a 79, but I'm not sure if the 79 had electronic or points ignition.
I'm also wondering if later model coils would fit and work. For instance there a couple sets of dual secondary coils for ZX6's on there too.
  • bountyhunter
  • bountyhunter's Avatar
Re: Coil questions
02 Jun 2008 12:43
#217444
My 1979 KZ-750 definitely has points.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Coil questions
03 Jun 2008 07:41
#217606
The 80 LTD has an electronic ignition. The primary resistance of yor coils depends on whether there is an online ballast resistor or not... I have a 79 and 80 shaft and both used 2.5 Ohm coils with 1.5 Ohm inline ballast resistor. To use 3 Ohm coils, you just have to remove the ballast resistor from inline with the wire that powers the coils.
  • riverroad
  • 1980 1000LTD B4
Re: Coil questions
03 Jun 2008 08:03
#217609
Thanks Bountyhunter and Wiredgeorge!
So then I take it that pre '80 points type models have 3 ohm coils? And I can use them if I just remove my ballast resistor from the cicuit?
Piece a cake!
One more question: If I decide to shell out the bucks for soem Dyna coils, which color ones are the 3 ohm coils? I'm thinking they're green. That right?
  • ssbn659
  • ssbn659's Avatar
Re: Coil questions
03 Jun 2008 10:27
#217648
My 80 KZ650LTD has points. I don't know what the spec on the coils are.
1980 KZ650E1 LTD, Free but not run in over 10 years.
Until now that is :-)
  • Jack
  • Jack's Avatar
Re: Coil questions
03 Jun 2008 11:20
#217654
Yes,the Dyna 3 ohm. coils are green.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • wiredgeorge
Re: Coil questions
03 Jun 2008 11:22
#217655
Buy the green Dyna coils. Remove the ballast resistor if one is installed.
  • wiredgeorge
Re: Coil questions
03 Jun 2008 11:25
#217658
ssbn659 - We are discussing a KZ1000. All the KZ1000 models used an IC igniter ignition by 1980. If you have the OEM coils, they are the same as the green Dyna coils being discussed... they are called 3 Ohm coils. Most of the time the actual primary resistance will just over 4 Ohms but they are called 3 Ohm coils.
  • jimmybon
  • jimmybon's Avatar
Re: Coil questions
30 Jun 2008 05:14
#222996
Is there a ballast resistor on a 77 kz650?
and if so , whats it look like or were could i find it?
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
  • riverroad
  • 1980 1000LTD B4
Re: Coil questions
30 Jun 2008 06:57
#223019
If you have one, it'll be a white ceramic brick looking thing up under your tank, ahead of the coils. About four inches long, half inch thick.
  • OnkelB
  • OnkelB's Avatar
Re: Coil questions
30 Jun 2008 08:15
#223036
No. Obviously I can´t know if someone put low-ohm coils on your bike and added a ballast resistor, but with the stock setup there shouldn´t be one.
77 KZ 650 B1, 82 GPz 1100 B2.
  • bountyhunter
Re: Coil questions
30 Jun 2008 12:22 - 30 Jun 2008 12:23
#223099
I believe the stock coil in mine is four Ohms, no ballast resistor.
Last edit: 30 Jun 2008 12:23 by bountyhunter.
