Dropped bike, now no power
- Afrosemite
01 Jun 2008 18:05
So, after spending the better part of a day working on getting my carbs cleaned I finally get to the point where I am go out see how it runs.
About 100 feet down the road I hit some real loose gravel and end up dropping the bike because I'm an idiot. Anywho
Now I get no power out of anything and am blowing my main fuse. Any thoughts on what I could have pinched or how I should go about using my multimeter to figure out whats going on?
\'78 Kz650d sr
- OKC_Kent
Re: Dropped bike, now no power
01 Jun 2008 18:09
Check the battery, you may have jarred something loose or the + cable is grounding out...
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- bountyhunter
01 Jun 2008 19:06
If it fell on the side, check the turnsignal stems and wires running through them. They get yanked and may have the insulation torn at the corner grounding out.
- Afrosemite
01 Jun 2008 19:42
so how should I be using my ohmmeter to test this? Just connect to the frame and poke different wires waiting to see 1? Key on or off? (only burns fuses while on) What range for the meter? I'm no good at this stuff but I can imagine a should would charge a lot to fix it.
Could this have anything to do with the new points that were just put in?
\'78 Kz650d sr
- bountyhunter
01 Jun 2008 23:07
Afrosemite wrote:
Points should have nothing to do with it.
carefully check any bulbs or bulb sockets that got damaged or the wires going to them.
Key off when using the Ohm meter to find wires touching ground. Put one lead on ground and poke away. range of 1X is best, you are looking for a short of less than a few Ohms.so how should I be using my ohmmeter to test this? Just connect to the frame and poke different wires waiting to see 1? Key on or off? (only burns fuses while on) What range for the meter? I'm no good at this stuff but I can imagine a should would charge a lot to fix it.
- Afrosemite
03 Jun 2008 20:27
can carefully check mean to just unplug? I am pretty confused about what I should actually be doing. I went outside and cleaned all the connections I could find with the connection cleaner, greased them, and still exploding fuses.
I may just not be looking carefully enough at the connections and, it's very likely, that I just have no idea what I am doing with this multimeter.
Sorry for the negative tone, I'm kind of stressed about this
\'78 Kz650d sr
- bountyhunter
04 Jun 2008 15:32
Afrosemite wrote:
To use an Ohm meter to find a short to ground, you connect one lead to chassis and poke around with the other lead. It will beep or read low Ohms when you find the short.
Check wires for damage to the insulation going around the corners that could short.can carefully check mean to just unplug? I am pretty confused about what I should actually be doing.
