Got a new CSR750 but need help (pics)
  • George4
  • George4's Avatar Topic Author
30 May 2008 19:07
#216869
Hey guys, this is my first post here and I just bought a 1982 Kawasaki CSR 750 with 8k mi for $30. It has good compression but no spark. I cant get power to anything. Now I have found a blown fuse, a striped wire, and 2 wires connected that I don't think should be. If I could get someone to tell me where these wires are suppose to go or give me a wiring schematic that would be great. I know the bike needs some paint and some major cleaning but I need to hear it run first. If you have any good links for info on this kind of bike that would be helpful also. Thanks.
~George
~George
1982 Kawasaki CSR 750cc twin
1975 Kawasaki F11-B 250cc 2-stroke
2000 Toyota Camry 2.2L I4
1989 Modified Mazda RX-7 1308cc Rotary
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
Re: Got a new CSR750 but need help (pics)
31 May 2008 01:45
#216912
Welcome George4...$30.00!?!?! Wow. But, there is a wiring diagram posted, for your bike, under 'KZ Information', then under 'filebase', then under '1982', then under your bike. It is a pdf file so you'll need the free reader.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Beatpoet
  • Beatpoet's Avatar
31 May 2008 02:01
#216913
The ignition wiring is simple...
Battery -> Kill Switch -> Coil primary -> Ground through Points.
Check primary and secondary resistance through the coil, get new plugs and probably plug caps.
Clean the fuel passages, get fresh gas and Vrooom!
Now why can't I find a bike for $30? :blink:
  • steell
  • steell's Avatar
31 May 2008 06:28
#216926
82 KZ750 CSR is a twin with electronic ignition, so you probably ought to wire the igniter in also :)
  • George4
31 May 2008 07:02
#216930
Wow, that was just what I needed. Thanks a lot, now I will try to get this figured out.
~George
