Strange problem!!
- Bullitt03737
Strange problem!!
28 May 2008 18:30
Very simple question. 81 CSR M1. When you turn the wheel to the left and turn the key all the way clockwise to lock it. The tailight comes on and stays on. Any ideas? Greatly apprciated.
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- The Milkman
Re: Strange problem!!
28 May 2008 19:03
On my 78 650 the switch position all the way clockwise is an accessory postion the tail light comes on and you can use the 4 ways if necessary without having the ignition for the coils turned on.
- JR
28 May 2008 19:25
Same here
Turning the key clockwise will lock but will leave the tail light on. Did it one night by accident and came out to a flat battery :S next morning.
To lock the bike turn the key to the left (anticlockwise).
- Bullitt03737
28 May 2008 20:11
Thats great to hear. That means I dont have to chase down a electrical gremlin. Thank you for the quick responses!
- PLUMMEN
28 May 2008 20:53
parking light;)
- Bullitt03737
30 May 2008 08:42
Well the it functions how you say to turn on the parking light. But the key just wont turn the other way to lock the wheel. Whats the trick?
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
30 May 2008 10:40 - 30 May 2008 10:40
It can sometimes get a little stuck. Try turning the handlebars a bit, then turn the key again. You can also try pushing the key in as you turn.
West Linn, OR
Last edit: 30 May 2008 10:40 by Skyman.
