Does battery effect performance?
  • jbrewer73
  • jbrewer73's Avatar Topic Author
28 May 2008 10:37
#216389
I have a 1977 KZ1000 and want to know if a bad battery will effect your performance?
I was told as long as all other electrical components are fine and once the bike starts and rides the battery has nothing to do with the performance. Rectifier, coils, stator is all fine.
Can someone clarify please??
Thanks
  • 76 LTD
  • 76 LTD's Avatar
Re: Does battery effect performance?
28 May 2008 11:23
#216398
yes it will affect performance.not to mention making the alternator work itsself to death trying to run everything on the bike plus charge a junk battery.battery is a lot cheaper than alternator or regulator/rectifier.
  • bountyhunter
  • bountyhunter's Avatar
28 May 2008 16:08 - 28 May 2008 16:09
#216473
Thanks
That's true if and only if the battery is good enough that the alternator can bring the system voltage up to the normal 14V when the engine is running (many times that will be true). If the battery drags it down below 14V, it can affect performance (specifically the voltage the coils have to make spark with).
Last edit: 28 May 2008 16:09 by bountyhunter.
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
28 May 2008 17:42 - 07 Feb 2013 03:28
#216480
79 KZ1000ST
Past:
Many.
Last edit: 07 Feb 2013 03:28 by KZ250LTD.
