1982 KZ 750E headlight
  • Ituen
  • Ituen's Avatar Topic Author
  • Rider
25 May 2008 18:24
#215791
Does anyone know what the part number is for the 1982 KZ 750E headlight?
1982 KZ750 E
Kawasaki Rider
  • SPARKY47
  • SPARKY47's Avatar
  • 1980 KZ500 B2
Re: 1982 KZ 750E headlight
25 May 2008 18:39 - 25 May 2008 18:40
#215794
HEADLIGHT ('81 -'82 KZ750-E2/E3) Partslist for 1982 KZ750-E3
img# Quantity Part Price Area Serial#
11034 Not Available
Add to wishlist button
110341674
BRACKET,HEAD LAMP
€ 89.50
11034A Not Available
110341675
BRACKET,HEAD LAMP UND
€ 3.50
11074B Not Available
110341676
BRACKET
€ 6.50
13091 add to shopping cart button
23074001
RING,HEAD LAMP MOUNT
€ 21.50
14020 Not Available
23072001
€ 22.50
23004 Not Available
230041040
LAMP-HEAD
€ n/a
23005 add to shopping cart button
23005101521
BODY-COMP-HEAD LAMP
Only 2 left! € 117.50
23006 add to shopping cart button
23006038
RIM,HEAD LAMP
€ 47.00
23007 add to shopping cart button
230071009
LENS UNIT,HEAD LAMP
€ 86.00
49016 add to shopping cart button
490161016
DUST COVER
€ 11.00
92001 add to shopping cart button
92007024
BOLT,10MM
Only 2 left! € 4.00
92009 add to shopping cart button
23019021
SCREW FORCUS ADJUST
€ 2.00
92009A add to shopping cart button
23019022
(92172-0145) SCREW,PAN HEAD,5X14
Note: this part is superseded by 921720145. € 1.00
92009B add to shopping cart button
23019023
SCREW-PAN HEAD,5X12
€ 2.00
92015 add to shopping cart button
23020018
NUT,4MM,FOCUS ADJUST
€ 2.00
92015A add to shopping cart button
23020023
NUT,HEAD LAMP RIM FIT
€ 2.50
92015B add to shopping cart button
920151078
NUT-6MM
€ 2.00
92015C add to shopping cart button
920151428
NUT,FLANGED,10MM
€ 2.00
92022 add to shopping cart button
23021004
WASHER
€ 1.50
92022A add to shopping cart button
23021012
WASHER-PLAIN,5MM
€ 2.00
92022B add to shopping cart button
92022125
WASHER 6.5X20X1.6T
€ 1.50
92027 add to shopping cart button
23052011
COLLAR,HEAD LIGHT
€ 7.00
92027A add to shopping cart button
92027162
COLLAR,6.8X10X12
€ 3.00
92069 add to shopping cart button
920691002
BULB,12V 60/55W,H4
€ 45.50
92071 Not Available
920711008
GROMMET
€ 3.50
92075 add to shopping cart button
23066021
DAMPER RUBBER
€ 5.00
92075A Not Available
23066022
DAMPER RUBBER
€ 5.00
92075B add to shopping cart button
920751243
DAMPER RUBBER
€ 3.00
92075C add to shopping cart button
92075209
(92160-1162) DAMPER
Note: this part is superseded by 921601162. € 2.00
92081 add to shopping cart button
23014005
SPRING FOCUS ADJUST
€ 1.50
110 add to shopping cart button
112B0614
(112G0614) BOLT-UPSET 6X14
Note: this part is superseded by 112G0614. € 2.00
110A add to shopping cart button
112G0625
BOLT-UPSET
€ 2.00
114 add to shopping cart button
115G0816
BOLT-SMALL-UPSET,8X16
€ 0.50
220 add to shopping cart button
220B0312
SCREW PAN HEAD 3X12
€ 2.00
411 add to shopping cart button
411B0600
WASHER PLAIN 6MM
€ 0.50
411A add to shopping cart button
411D1000
(92200-1313) WASHER-PLAIN,10MM
Note: this part is superseded by 922001313. € 2.00
461 add to shopping cart button
461F0600
WASHER SPRING 6MM
€ 0.50
461A add to shopping cart button
461F0800
WASHER SPRING 8MM
€ 0.50
Any help? Its all in euros[funny money]:)Taken from cmsnl.com
1980 KZ500 B2
Last edit: 25 May 2008 18:40 by SPARKY47.
  • Ituen
  • Rider
26 May 2008 02:52
#215885
Thanks!!
1982 KZ750 E
Kawasaki Rider
