dyna-s install help!!
- downhandonly
22 May 2008 19:53
hi there! okay here's the deal I installed a pair of dyna 3 ohm coils removed the ballast resitor and then proceeded to install my dyna s and bam! my bike does'nt have points! it has the same kinda pickups and rotor thingy that the dyna s is but I really want to put the dyna s on anyway. OK my question is...there are 2 wires going to one side of the pickup and two to the other on the stock plate. I traced the wires to behind the sidecover to the IC igniter. I want to know if I install the dyna s do I toss the igniter and do some kinda fancy wiring or splice the green wire from the dyna to the 2 corrisponding wires that go the the proper coil and the black wire to the 2 wires that go to the other proper coil and then run the red one to the switched 12 volts??? anyone come across this one before?
80 KZ1000 LTD
- l0g1c
- Hanging on for dear life.
Re: dyna-s install help!!
22 May 2008 20:23
Yep, remove the ignitor (don't throw it away).
Here's the instructions from the Dyna site regarding the wiring.
Dyna S Install
Dyna S Install
'81 KZ750 LTD
'72 CB350K
Omaha, NE
'72 CB350K
Omaha, NE
- downhandonly
