coil oum ??
- ironleg
- its not what you ride its why
coil oum ??
22 May 2008 19:24
i hope i spelled that right what oum are stock 78 1000 coils and would 1.5 oum coils be good or bad to run and does it mater what the coils came off of as long as the way thay fire the same way
78 1000 ltd current project
75 z1 900 Dragbike 78 frame GS 1100 swing arm yamaha rear wheel dyna-s dyna 2 step best time 12.02 1.59 60ft
71 harley shovelhead chopper
2002 harley springer softail
1999 yamaha 600 grizzly
- l0g1c
- Hanging on for dear life.
Re: coil oum ??
22 May 2008 20:15
oum = ohm
You don't want to run coils that are lower in resistance than what the rest of your ignition system is built to take, or you'll burn something up (I think the coils would go).
I'm afraid I couldn't find the resistance for your coils, but if I had to take a stab at it, I'd guess they're 3 ohms. Hopefully someone will come along and verify/invalidate that for ya.
'81 KZ750 LTD
'72 CB350K
Omaha, NE
'72 CB350K
Omaha, NE
Re: coil oum ??
23 May 2008 07:29 - 23 May 2008 07:31
l0g1c wrote:
That is correct -- 1978 KZ1000 has two coils. Each coil is a 3 ohm coil with dual plugwire outlets.
One of the coils (usually the one mounted on the bike's lefthand side nearest the shift lever) fires the outside plugs #1 and #4.
The other coil (usually the one mounted on the bike's righthand side nearest the rear brake pedal) fires the inside plugs #2 and #3.
The important coil characteristics are that each coil should be a 3 ohm coil with dual plugwire outlets.
Good Luck!
...guess they're 3 ohms. Hopefully someone will come along and verify....
Good Luck!
Last edit: 23 May 2008 07:31 by Patton.
